For many years I have used Plugwise with Plugwise Circles and Stealth modules to monitor my solar panels. This has worked flawlessly since around 2010 and is running to this day because I still have no better alternative.
I have 5 PV units running (around 13KWp) via Stealth and Circles.
With plugwise I can see the output per hour for every unit, but also combined in a group.
Major advantage is that a PV inverter is not coupled to a specific measuring device. When a Circle dies, I simply put another one in and connect it via the software to the specified device. In homey I use Shelly’s to measure the inverters. One Shelly died and so did the history because it is coupled to the Shelly and not to the Inverter. Also replacing a inverter I should not need to be losing all history data.
In Plugwise this is separated which works fantastic. In plugwise I can select, hour, day, week, month and year en put a from and to date and I get all the graphs and stats that I need, plain and simple.
I just need to get rid of Plugwise, because the hardware a starting to fail after 16 years of use. More and more Circles fail to keep the relays powered (failing capacitors etc.).
Also every appliance in the house I keep track off via Plugwise. I’m planning to replace them all at once for INNR zigbee smart outlets.
What I really need is some way to create devices in Homey, that power logs are written to that device and when the hardware fails I can just assign a new device continuïng where the old device has left. I don’t seem to be able to do that. I’ve tried with virtual device, but that does not seem to work.
Also grouping devices does not do the trick.
I’m at a point that I’m giving up. It gets more complicated every time I try to fix things. Even simple things like the energy monitor, where I say the Shelly’s are my PV panels, it registers the data plain wrong. Made virtual devices to invert the values, but then things elsewhere are messed up.
Does anyone have some tutorial that actually works for me to straightforward set things up?
I would love to start 2026 measuring my power usage and PV panels via Homey, but I’m tempted to sell everything and start over completely with a different system.
Thank you very much.
