[Matter] IKEA DIRIGERA hub en IKEA Home smart - Central topic
Central Topic for IKEA DIRIGERA hub en IKEA Home smart connected using Matter to Homey Pro.
Will Link and/or move some Topics / Posts from other topics here.
This Topic is NOT for use of the Non-Matter integration, like other Homey Apps:
Links to other relevant Topics:
Does anyone know if the new IKEA Dirigera-hub will be supported to connect to from the homey? This because I have a lot of Zigbee Devices from IKEA connected directly to my Homey but now it is becoming more and more unstable.
It’s only been available from today, so I guess we’ll have to wait to at least find out if the new hub offers a local API like the old hub did.
any news on development for the dirigera?
i do have one at home but dont know how to develop for it.
i do want to help test it
Personally, I don’t think a specific app will come. But I do think it will be supported in the (near) future due to the fact that it supports Matter and the new Homey Pro also supports Matter. I therefor hope dat you can direct lights, plugs etc via Matter then.
My question about this is for the current homey pro. Not the new one. And hoping for support through this hub to get kind of matter support.
Got it working for now trough home-assistant. Not the best way to do it, got a bit of lag, but they already support it.
I bought the new dirigera for the matter support, got a homet pro 2019 and is working fine so not going to buy a new homey pro just for matter.
Should be supported to offload the ZigBee load on the homey as I am also trying to move a lot of ZigBee devices now to the DIRIGERA as the homey is lagging ZigBee support when having a lot of devices.
So best would be to add this new hub to the homey control to integrate as that’s where the homey is for.
I think the existing IKEA Trådfri Gateways app might be a good base; did a “port scan” an the Dirigera hub today and see that its looks to act similar and also has a security code etc and should have API’s available on the ports.
Host is up (0.00098s latency).
rDNS record for 192.168.1.176:
Not shown: 997 filtered ports
PORT     STATE SERVICE  VERSION
8082/tcp open  http     node-static httpd 0.7.9
| http-methods:
|_  Supported Methods: GET HEAD POST OPTIONS
|_http-server-header: node-static/0.7.9
|_http-title: Site doesn't have a title (text/plain).
8443/tcp open  ssl/http Node.js Express framework
|_http-cors: POST PUT DELETE PATCH
| http-methods:
| ssl-cert: Subject: commonName=DIRIGERA HUB FOR SMART PRODUCTS02099011411ADCF82C0139/organizationName=IKEA of Sweden AB/countryName=SE
| Issuer: commonName=IKEA HOME SMART DEVICE TRUST/organizationName=STMicroelectronics nv/countryName=NL
| Public Key type: unknown
| Public Key bits: 384
| Signature Algorithm: ecdsa-with-SHA384
| Not valid before: 2021-03-03T00:00:00
| Not valid after:  2071-03-03T00:00:00
| MD5:   ae48 84ed 1d75 f6a2 6edd b7d3 76e0 dd7e
|_SHA-1: 83a6 44b8 9cdc d557 26ed cb3b 8882 fb68 e8a8 0292
9000/tcp open  http     Golang net/http server (Go-IPFS json-rpc or InfluxDB API)
| http-methods:
|_http-title: Site doesn't have a title (text/html; charset=utf-8).
Any new updates on the Diregera suport for Homey ?
The Diregera know for me works very good and very responsive.
It seems theyve updated their shit.
KR
Tom
There isn’t any.
Is there anyone who can make an app for the dirigera hub? There is some work done already here GitHub - dvdgeisler/DirigeraClient: Dirigera Client API: Java written client API to interface IKEA's new smarthome hub DIRIGERA. And as noted by @Edward_Moll, the IKEA Tradfri Gateway app might be a starting point. Although that app needs to be updated as well :slight_smile:
I see that I’m losing intrest in Homey due to the lack of this integration. Homey will be reduced to an integration bridge for unsupported z-wave devices to Apple and Google home.
Dirigera and Hue will have direct integration.
Same here. Currently negative advising to buy homey as the integration is not supporting the Ikea is still lagging and looking into alternatives for the homey as integration hub and remove it completely.
Also the netamo stuff is not working correctly as the temperature can not be set due to wrong api call etc. So now have lagging support for two vendors already
:sleepy:
What do you need hub-support for? Homey supports the devices without the hub, and when homey starts supporting matter it will be even better
  • The IKEA hub supports more devices than the current Homey Pro
  • The IKEA hub supports grouping/binding
  • The IKEA hub supports OTA firmware updates
  • Matter will not be made available for the current Homey Pro
ok, fair enough. But im sure a developer will be making an app for this any time soon
Main reason is also to stabelize a large zigbee network, like having a lot of troubles with the homey to keep stable over time when having +60 zigbee devices in one network… so adding the hub makes it stable… (proven) but disconnected from the single controller…
so i moved now almost all ikey lights that are controlled by simple buttons and/or time based or motion detectors to the hub and using google nest hub to control them… as homey can not…
Any more news on Dirigera and Homey?
I didn’t realize there’s a Trådfri and a different Dirigera Smart Hub. Now I moved all Ikea things from Homey to a new Dirigera Hub, but I cannot connect it to Homey?!? Do I understand this correctly? :cold_sweat:
