Hejhome Pika TS0601
Title: Please add multi-gang support for Hejhome Pika TS0601 (_TZE284_c8ipbljq) – 3‑gang and 6‑gang
Details:
  • Homey model: Homey Pro
  • App: Tuya Zigbee
  • Device brand/models:
    • Hejhome Pika 3‑gang (GKZSW391L2DB03)
    • Hejhome Pika 6‑gang (GKZSW391L2DB06)
  • Zigbee fingerprint:
    • Manufacturer: _TZE284_c8ipbljq
    • Model ID: TS0601
    • Product ID: TS0601
  • Behavior:
    • Pairs as device type “Router”.
    • Only one switch tile is created.
    • On/off control doesn’t work under generic Zigbee, and also not when pairing via Tuya Zigbee multi‑gang tile.
    • Advanced settings do not show endpoint/cluster list.
  • Expected:
    • Each gang should be exposed as a separate switch (3 tiles for GKZSW391L2DB03, 6 tiles for GKZSW391L2DB06).
  • Request:
    • Please add this fingerprint to the appropriate multi‑gang TS0601 driver and map all endpoints so each gang is controllable in Homey.
  • Notes:
    • Device pairs within 2–3 m of Homey Pro.
    • Factory reset performed before inclusion.
Please search for the Tuya Zigbee app threads on the forum and follow their instructions (explained in the first post typically) on how to request device support.
Also need to note, does show in Hejhome standalone app and works correctly however does not show in Hejhome Homey app(on a pro)
can you give me an example of a thread for this, I dont see any threads that deal with Hejhome devices… except the older ones that are already listed in the app
It’s a Tuya device, there are two Tuya Zigbee apps:
Before posting a support request, also make sure that your device isn’t actually already supported.
If you already have them in the Hejhome app, you can migrate to the Smart Life app and use them in Tuya Homey app
