Clicksmart+ - CMA30036 - 13A 2 gang zigbee smart switched socket outlet
Has anyone had success in adding this device to a homey pro? When pairing Homey seems to recognises its a zigbee wall socket stating there will be 2 elements (presumably L & R sockets) but when completing the install says it doesn’t recognise the device a just installs a generic Tuya tile with no actual connection to the socket.
Have tried installing via Zigbee, apps Tuya Zigbee and Universal Tuya.
Thanks
Gareth
Please don’t double post
@moderators
You can use the official Tuya app in combination with a Tuya MultiMode or ZigBee gateway.
Thanks, still can’t get it to work
Gareth
You can use commands to control it. Add it as an Unknown device in the Tuya app.
You can then use these cards to interface with the device.
I have loads of these. They dont work with the official tuya app but they do work with the experimental one
But. This is an experimental app. So as Sven says, it may be worth getting a Tuya Hub and then use the other app.
Hopefully someone can bring them into the official tuya app because they are great
Finally got it to work with the experimental app. Many thanks to everyone for your help.
Which version?
Be good to have a backup
It’s v5.11.25
