Scolmore ClickSmart+
Hi Guys, picked up one of the Scolmore ClickSmart+ double wall sockets (UK type).
Good looking socket and if i can get it to work would be interested in a quite a few of them.
Trouble is there is no app, i know this has been discussed before and i have read and try everything that has been suggested on here.
I can only get one of the two sockets to work using either a generic Zigbee device or the Tuya Zigbee App. Frustrating as it works very well, responds quickly and looks the part.
Just in case i am missing something i want to ask if anyone has tried these and managed to get both sides to work ?
If anyone out there is capable of writing an app, i would be interested in supporting them with devices ?
Andrew
Homey Pro 2023 on 10.3
No, just single wall sockets are supported as generic Zigbee device. For double wall sockets an app is needed.
You’d best ask for support here
And in the meantime, try the test version of the app, it supports many more devices.
(To me it looks like a Tuya whitelabel 100%, by looking at the Android app screenshots)
Thank you Peter, that does look promising.
I will try it when i get home.
Andrew
Close but no cigar !
Have put in a request for a new device.
I can see existing devices with same name, but different manufacture, so hope it is an easy (ish) task.
Andrew
Yeah, how convenient it would be when those devices were the same under the hood.
For sure @Peter_Kawa !
Been playing with this socket i have, but only set as a single gang, and it is quick and the range appears very good. It ticks a lot of boxes for me if i can get it added !
Not sure how long it takes to get it added as there seems to be requests going back to last sept on the Github. if i knew how to do it myself i would, but that is a bit beyond me.
Andrew
Hi All. Got Homey recently and slowly migrating over from SmartThings
These sockets worked well for me using the Tuya app. Thanks.
Anyone had any experience with the Aurora Aone 13a double sockets? I can only get one side to be seen by homey. That side works really well but its a double socket.
Is there a way to change the device type or app that handles the device?
Thanks
I managed to get the Scolmore ClickSmart+ double wall sockets (UK type) to work perfectly since the software was updated, very stable and fast. Have installed about 20 of them now.
No experience of the Aurora sockets sorry
Ive got a few of these but only managed to get the 1 socket working using the generic zigbee setup (no app)
Are you able to get both working it so what app are you using?
Many thanks
Edit: Apologies I see you’re using the tuya Zigbee app. Just installed this and have both sockets working great.
Are these reliable for you then with homey? Ive been using them for a long time with hubitat and worked fine and never dropped off the network. Ive recently switched to homey and these were the one thing I couldn’t get properly working until I saw your post.
Thanks
Use the Tuya Test app as mentioned above. Works a treat
Thanks, yeah sorry edited my post above after I noticed its using the tuya Zigbee app.
I have Scolmore Click Smart+ sockets (ZigBee) and I made this app which works quite well
I will release it one day but I don’t have time at the mo (house renovations etc, hence the snazzy sockets).
