Various dimmers and switches turns both On and Off at random times. Not even the same dimmers are involved.
How can I solve? Anyone else experience this?
It’s a bit annoying when your bedroom light turns on during sleep…
Hej Christoffer,
A question, do you have a log card to all action parts of your flows? Like, Papertrails, SimpleLog, Timeline, Callmebot, Telegram etc.
Only then you can filter out what is happening.
For instance, I scratch my head quite often about ‘new phenomenons’. In the end, it almost always seems I edited or added something in my flows which caused the unexpected ‘malfunction’.
There have been more reports about (especially) Hue turning itself on or off.
I haven’t seen the cause/solution yet.
Turn off the lamp when [brand X] has turned on the lamp
This is possible with the Device Capabilities app
In my example I used ‘Tuya cloud’ instead of ‘Fibaro’
If you have created the flow below:
then turn on the lamp with the Mobile Homey app, and look in the timeline notification for the exact name of the client (client = the app or service that turned on the lamp).
Now you can create this flow, and use the client’s name as a filter
Timeline results, bottom report is from the 1st flow, top one is from the 2nd flow:
I would suggest to contact Athom.
By the way, this is not the only case that a Fibaro device turns on/off by itself (see this German language thread).
@Peter_Kawa, I have tried your workaround. However, the result is nothing different than the info in the device timeline. Or am I missing something?
