Hope you guys can help me troubleshoot.
Setup (hasn’t changed for two years)
Homey 2016
4 led spots under carport
Fibaro dimmer 2
2 flows currently active:
Flow triggers lights at sunset (ON)
Flow triggers lights at sunrise (OFF)
For a week or two this strange thing happens.
After carport lights are triggered on due to flow 1, at some (seemingly random) point in time the lights go off and on.
I’ve taken a screenshot for your info.
After this series of off/on the lights just work normally.
I tried to trigger the auto calibration function.
I also tried disconnecting the fibaro dimmer and reconnecting.
Not sure where to look next.
The log just has a timestamp, doesn’t tell me what triggered the state change.
Did you happen to solve this? I am experiencing similar issues with 1 Fibaro Dimmer 2.
It only occurs when we are at home during day time (e.g. working from home). The light will turn off and then back on 2 minutes later. There is no flow doing that, and also in the device log you can see that “Fibaro” performs the action. Normally that means someone pressing the physical button.
The same light is one entire nights, and then never has this same issue.
