Gledopto
I use hue. This site was helpful for the generation of the color temperature hex codes:
https://www.color-blindness.com/color-name-hue/
In my case a good match for warm white is the hex code: ffa600
@MarcoRuiter i found a way to set the white color like I wanted so info is not needed anymore.
I found out that by using card “set temperature” it would set white color from cold to warm.
Can someone confirm it works with Homey 5.0 RC XX? :slight_smile:
i have the same problem …
i have 2 of Gledopto RGB+CCT zigbee controller model GL-MC-001pk
and it recognizes the device but can only make it a universal Zigbee device.
only on/off … plz add support
I’m looking into the gledopto products and looking to buy some rgb cct controllers. I see there is a normal version which is supported and a Pro version which I don’t know for sure. Can anyone tell if it is supported?
im using three GL-C-008S which work perfect.
Thats the white one right? I mean the black one the pro version
the 008s is white indeed, i dont know from you table if thats an 008s
i bought these: Gledopto Zigbee Led Controller Rgbcct 12V 24V Werk Met Amazon Alexa Echo Zigbee 3.0 Gateway Smartphone App Voice afstandsbediening|RGB Controlers| - AliExpress
€ 14,35 50%OFF | Gledopto Zigbee 3.0 Led Controller Pro Rgbcct Strip Controller Smart App Voice Control Werk Met Amazon Echo Plus Smartthings Rf
Gaat om deze
@MarcoRuiter is it possible to add one or both of the remotes to Homey?
The products can be found in the link below, it is a remote and a wall switch:
€ 11,81 | GLEDOPTO ZigBee 3.0 LED Controller Pro RGBCCT Strip Controller Smart APP Voice Control work with Amazon Echo Plus SmartThings RF
Mine don’t seem to work either I got a couple of e14 RGB candles. They are recognised but I can’t do anything with them. Switching them on en off doesn’t work also since upgrade to V5.0. Does anyone have any advise.
I did PTP and also tried pairing them again to homey. Pairing works but they don’t seem to send or receive anything.
After updating to v5 and installing this test 2.0.5 version app I managed to get my ledstrip driver (GL-C-008 rgb+cct) paired! Thanks @MarcoRuiter It had lying gathering dust for years :grin:
There is only an issue when changing the color from rgb to cct. If you need any info let me know
Also just found out…
Hey there, after homey 5.0 update my tint RGB bulbs are not working anymore. Are shown in homey but do not respond at all.
Anyone with the same issue here?
Any ideas on how to fix?
Beta of the app already installed…
Created PR Bugfix/solve gl c 008 error by josser84 · Pull Request #55 · mruiter/com.gledopto · GitHub to solve GL-C-008 error message [expected_new_range_start_number] · Issue #45 · mruiter/com.gledopto · GitHub ( expected_new_range_start_number). This solution can be used for other controller that might have the same issue
That remote is not using zigbee but 2.4g rf signal. I’m not sure homey can even intercept that
Great news!
The Gledopto GL-S-007Z and GL-C-008P lights are completely functioning now, very happy with it!
Please all community members, add all the information you have to this list and build it toghether.
Thank you all who already added some lights, and thank you all who can provide information.
If you want me to add to the list than give all the needed information in this topic.
Tested with the Homey v5.0.4 RC (experimental) firmware and the Gledopto/ tint app version 2.0.8 (Experimental) version
link to the topic:
Hi All, respect and thanks for all the team work around this great app. Since GL-C-008P has been added, I use the app.
I’d like other Pro items to be added, like GL-D-004P, GL-C-006P, GL-C-007P. All of these are supported without the “P” ending in the PN.
How could I achieve it? It seems I could manage to make these and also other items sent by Gledopto to the one who would do the effort.
@MarcoRuiter I noticed that the repository is no longer visible. Are you still actively working on this? If so, the links for bugs and questions on the Athom app store still point towards the non accessible repo. Maybe this can be updated?
I used to do some minor changes in the past and was also following up some of the issues. Is there a way to access these again?
Oops Good morning Friend, dude I bought One of this black ones equal to Your Pro Version, but I’m not able to make it go into pairing mode, I’ve already tried to turn it on / off 5X Didn’t get Success, any secrets when it comes to pairing?
