i’m running a homey self hosted server. And i have bought the gardena smart gateway and smart soil sensor wich are running fine and is connected to Homey.
Maybe the smart water controller has a different internal identifier than older controllers, which the Homey Gardena app doesn’t yet support. So it’s possible that the Homey Gardena app needs to be updated.
That’s why I would recommend contacting Athom support, since Athom is the developer of the app. → Support | Homey
Thanks i susspect the same, as the icon in homey is showing the old water control and not the new water control. I have raised an ticket and post the outcome here
The icon doesn’t necessarily mean that a newer device isn’t supported. Some apps use a single icon for different versions.
In any case, I’m curious to hear Athom’s response.
You where correct, i have requested that they support this model. As the old water control has been discontinued
At the moment, the latest Gardena Smart Water Control (and the Dual Water Control) aren’t yet supported by the Homey Gardena app, which is why it doesn’t appear in Homey.
I can’t get my Smart Dual Water Control to work either, but I’ve added a request: Gardena | Homey - please chime in there so we can hopefully get some attention to the issue!
You mention a Homekitty workaround for the Smart Dual Water Control.
Could you explain how you connected the Dual Water Control to Apple Home and whether you’re using a Gardena Smart Gateway?
Added support for new water Control (2026) and Dual Water Control
But my app version is stuck at 2.4.1. When I install the app through: Gardena | Homey I get the latest version, and I see the new smart water control icons. But I can’t add any device, even my sensor now fails: `Cannot read properties of undefined (reading ‘value’)`
Edit
Seems like a cross-origin issue: Unsafe attempt to load URL https://x from frame with URL https://x. Domains, protocols and ports must match.
