Gardena water control cannot be added
At least we know this is just around the corner, just a matter of days before a working version 2.5.1 is pushed to Homey, I would think?
Same here, stuck on 2.4.1…
I was able to install the 2.5.1 version. But when I try to install the Smart Dual Water Control it asks me to login to the Husqvarna site. Doing so immediately after logging in it says No new devices found.
Tried to register my smart water control at the Husqvarna site, but no idea what the 9 digit product number is.
Working now, with 2.5.2
That 2.5.2 needs to be put live? Only available as test now?
Just install it as test, works perfectly
Testing is over, it installed automatically and the dual water control works!
Hi There!
new on this forum :slight_smile:
just bought the dual water control without the gardena hub, the device is in pairing mode but homey does not find the device when setting up.
Am I missing some steps?
I beleive you need the gardena hub. Otherwise it won’t connect
i also have this problem any clue? tips?
i have the same problem what is the solution
do you need the gardena smart gateway to make it work?
Yes you do need the gateway from gardena
Yes, it will not work without it. It is also in the documentation of the app.
for me it works flawlessly with the new version.
(My workflow I use it now for is to turn on all the sprinklers in a zone if a cat dares to show up…)
