I switched from Homey Bridge to Homey Pro, erased all apps and flows from my bridge and set them up again in Homey Pro. Bridge is now connected in satellite mode as “bridge” to my Homey Pro
However: standard presence messages are now sent out from both gears. I’ve tried to disable presence in the bridge, but then it’s also disabled in the Pro and I don’t get any presence messages. Why could that be? Or did I make mistakes when setting up the bridge in satellite mode?
If you’re still getting messages from Homey Cloud (not the Bridge, the Bridge doesn’t run apps or flows), then it sounds like you didn’t remove all the flows there.
@robertklep: just gave it another check: there are no flows in Homey Cloud…
Perhaps contact Athom support: https://support.homey.app/hc/en-us/articles/360015784034-Submitting-a-support-request
Why are you using a Homey (Cloud) ? is that intended? as you don’t have Flows.
If you wanted to replace it, Delete the Cloud Homey !
Else if you don’t want to delete the Homey (Cloud) you should disable the Push Notifications on then Homey (Cloud) in More … TimeLine
(By default ON and only for a Homey Owner!)
Thanks, Dijker, I wasn’t aware of this setup panel and finally this did the trick! No more messages from Bridge, thank you! ![]()
