Aren't there airconditioning (airco or AC) devices/apps in Homey?
Hello Wim,
last year you posted a topic to command your Mitsubishi Heavy Industries airco with Homey.
Also got a MHI airco with the Airconwithme wifi module.
How do i use the information on the Github link you posted?
Do i have to copy al the data from the parts and paste it into a new script?
I hope you can help me with this and thank you!
Greetings Remon
Hallo Remon,
Ik doe dit ook niet dagelijks, maar: Allereerst moet je naar Github gaan. Met de groene knop kun je het bestand downloaden.
Daarna moet je hier op het forum even zoeken naar CLI installatie methode.
Er staat ergens een uitgebreide beschrijving. Daarmee installeer je de app vanuit github.
Het bestand com.intesis.acwm-master is een map.
In die map staan een aantal losse bestandjes, die je met node.js (CLI method) op jouw homey kunt installeren.
Daarna zou je de app Intesis Airconwithme by Ramon Baas tussen het rijtje apps op de homey moeten kunnen zien.
Succes !
Groet, Wim
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards/catregories:
https://community.homey.app/c/non-english
Thank you Wim!
I’ll try that.
Have a nice day.
Greetings,
Remon
Hello Wim.
I did it, now i can use my airco with Homey.
Thanks for the help!
Tnx for this! Just got my Airco installed today (second is up for next week) and this apps works out of the box. Great find!
Hi All, i am at the stage of buying an AC. I would love some advice from the homey com. Important for us. Quiet (for the neighbors and in the house) not to ugly unit for inside the house and of course working with homey!! Any suggestions?
I use a Mitsubishi Heavy Industries air conditioner (outdoor SRC50ZM-S) (indoor SRK50ZM-S). The outdoor unit is so strong that up to 3 indoor units can be connected. It is very quiet even at maximum power. The indoor units are controlled via a Switchbot Hub, which can learn all the commands from the remote control and sends all functions to Homey for control.
I’ve got two Mitsubishi Heavy Industries too. I’ve got them equipped with Airconwithme modules. The outdoor units, I don’t know if they make a loud noise since we don’t have neighbors close by. But indoors they are very quiet and installed yesterday the CLI app which seems to work great.
Inside unit is a SRK25ZS-W for my home office, downstairs is a bigger unit. For the outdoor unit there is 56dB noise level prognose, inside 50dB. The one in my home office is 2.5KW , the one in for my first floor is 5KW.
Also got a Mitsubishi Heavy Industries AC. It’s a split airco unit, same as Martijn.
The unit indoor is very quiet, outdoor no issues with the neighbours.
I have 2 Daikin Perfera indoor units(FTXM35R and FTXM20R )with one outdoor splitunit(2MXM40N)
Both indoor and outdoor unit are very very quit(max 60DBA)
The indoor units are equipped with a intergrated wifi board that connects to the daikin cloud.
Homey App is under development. Waiting for daikin to configure some technical stuff in the daikin cloud.
Helpfull info. Thanks a lot all
We have AC installed a couple of days ago. 2 Panasonic units with Nanoex. I already had a look at Sensibo as a connection between Homey and Panasonic but there is an app ‘Panasonic Cloud Comfort’ so i fortunately do not need to buy a Sensibo device.
I have created some flows but since the weather is a bit crappy these days i have to be patient. I already noticed the Panasonic temperature (actual room temperature) doesn’t update a lot so i’ve installed a Aqara temperature sensor to smoothen the temperature control for that room (for switching the AC unit ON and OFF). The app has a lot of features where you can control the fan position (up/down, sideways and speed) with the logic cards.
We have tried to make de WIFI unit work though Homey using the github file for the MHI. Through homey we can create a new device “Intesis Airconwithme” and change the login settings but when trying to connect with the Intesis Wifi device we get the following response:
─────────────── Logging stdout & stderr ───────────────
2021-10-19 12:30:26 [log] [IntensisACWMApp] IntensisACWMApp is running…
2021-10-19 12:30:26 [log] [ManagerDrivers] [MH-AC-WIFI-1] MHACWIFI1_Driver has been inited
2021-10-19 12:30:27 [log] [ManagerDrivers] [MH-AC-WIFI-1] Pairing started
2021-10-19 12:30:37 [log] [ManagerDrivers] [MH-AC-WIFI-1] Pairing started
2021-10-19 12:30:46 [log] [ManagerDrivers] [MH-AC-WIFI-1] Checking { ip: ‘192.168.1.37’, username: ‘admin’, password: ‘admin’ }
2021-10-19 12:30:49 [err] [ManagerDrivers] [MH-AC-WIFI-1] Error: connect EHOSTUNREACH 192.168.1.37:80
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1137:16) {
errno: ‘EHOSTUNREACH’,
code: ‘EHOSTUNREACH’,
syscall: ‘connect’,
address: ‘192.168.1.37’,
port: 80
What can we do to connect to the Wifi module and control it by Homey?
The wifi device is reachable through the webbrowser but somehow Homey can not connect to it
Is the device reachable using the IP-address mentioned in the log (192.168.1.37)?
Yes by the browser on a PC in the same network. Can i test this ip adress through homey somehow?
No not really, but the EHOSTUNREACH error is one that keeps popping up in other apps too. It sounds like a networking issue with Homey. Are you sure Homey and the device are on the same network?
Homey has network connection and can be pinged :
C:\Users\Gebruiker>ping 192.168.1.52
Pinging 192.168.1.52 with 32 bytes of data:
Reply from 192.168.1.52: bytes=32 time=12ms TTL=64
Reply from 192.168.1.52: bytes=32 time=9ms TTL=64
Reply from 192.168.1.52: bytes=32 time=11ms TTL=64
Reply from 192.168.1.52: bytes=32 time=2ms TTL=64
Ping statistics for 192.168.1.52:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 12ms, Average = 8ms
C:\Users\Gebruiker>ping 192.168.1.37
Pinging 192.168.1.37 with 32 bytes of data:
Reply from 192.168.1.37: bytes=32 time=1ms TTL=128
Reply from 192.168.1.37: bytes=32 time=3ms TTL=128
Reply from 192.168.1.37: bytes=32 time=2ms TTL=128
Ping statistics for 192.168.1.37:
Minimum = 1ms, Maximum = 3ms, Average = 1ms
Both from same PC is there a way to check a wifi/network connection from Homey itself? Homey ip adres: 192.168.1.52
wifi module ip adres:192.168.1.37
Like I said: no, not really. You could try rebooting Homey (or perform a PTP) to see if that solves the issue.
We are trying the PTP right now.
