@Jan-Feijen experimental should be fine
@martijnpoppen, done.
This is the report: 759bcb96-3608-4663-b8ad-ed086d7daebc.
Ps. When installing the option to enter S-Pin disappears quickly. I’ve entered S-Pin afterwards via menu.
New app update (TEST: 1.16.0)
Changelog:
- FIX: update library
- NEW: add updated_at capability to prepare for ABRP
Changelog:
Changelog:
Changelog:
Changelog:
More - apps - AppName - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the TEST version by clicking the link above and press install
Don’t want to be part of this TEST version? Install the LIVE version →
New app update (LIVE: 1.16.0)
Changelog:
Changelog:
Changelog:
Changelog:
Changelog:
It’s now possible to integrate with ABRP.
There’s a flowcard added to the VAG apps.
Then you can use that card as a trigger for your ABRP flow.
See:
Checkout the ABRP app here:
FYI: @SvenRhein @Martijn_C
@Jan-Feijen yes!
Working on something which might help debugging the issue.
Theres a change in the Audi API which influences a lot of cars. Seems like the same issue you experienced
So making a small tool in the app which we can use to debug. Was hoping to have it finished before the weekend. But the weather was so nice
The issue: Audi get vehicles broken · Issue #255 · TA2k/ioBroker.vw-connect · GitHub
FYI Audi Users.
Audi updated the API therefore all cars are not working with the current API.
See: Audi get vehicles broken · Issue #255 · TA2k/ioBroker.vw-connect · GitHub
Such a shame… Doesn’t work for me for a week or so now
You can help actually…
Have they done anything to the skoda also? I cant get any updates to my car for 7 hours. It doesnt want to even do anything with force update. Start or stop charge doesnt work from homey.
Heres debug 5efd57da-274b-4bf1-a52a-adbe3d717c07
All settings are default
@Dennis93 all VAG apis are really buggy lately.
I would say try again tomorrow. Sometimes its just stuck
Most of the time the official app also doesn’t work when the Homey app doesn’t work
What I have noticed is that one user account has issues while the other one has not.
Sinds then I have created an extra account for the homey integration. When it locks (maybe the number of times it connects or something else they track) I disable the app overnight and in the morning it works again. The login also fails in the VW app while another user in the app works fine. I had it update every minute and it happened more often that it stopped working. but now with 2 minutes it happened only once….
Wonder if the update could be set from a flow…. Then the interval could be less when I am sleeping or working and more frequently in between when you are likely to need up to date info of the car.
Switching user accounts on the homey app might also be something that might actually help (@ 2 update failures switch to other account)
@martijnpoppen those 2 options might be worth considering
I still have this issue that the app doesnt update if the settings doesnt come from the real app, then it updates on homey. So for an example it starts charing from the real app it shows that update on homey. But if i try to start charing through honey it doesnt send that to the car and it doest show any update to any info from the car
I did some more testing that is really wierd. I can turn off the charing from homey, but it doesnt work to turn it on. The integration from Home Assistant works both ways. Can it be something wrong in the code?
Tried turning of all my flows for the car but same issue. Heres a report: af77cb6c-847d-420f-b2fc-24ba0a591a1b
@Dennis93 yep looks like it!
Will investigate
[debug] {"type":"Start","chargingSettings":{"maxChargeCurrentAc":"Maximum","autoUnlockPlugWhenCharged":"Off","targetStateOfChargeInPercent":80,"durationInMinutes":null}}
[error] 400
[error] "create.operationRequestSettings.settings.targetStateOfChargeInPercent: muss null sein, create.operationRequestSettings.settings.autoUnlockPlugWhenCharged: muss null sein"
[error] failed set state charging
