Dear Martijn, versions of the app come and go faster than I move or charge my cars, so I can’t give you full feedback yet, but as soon as I see a problem (or not) I’ll let you know
Still not really working. Although at this moment the Skoda app itself is also not working very well. I have made an alternative flow to start and stop the charge from the charger instead of the car. That seems to work for now.
Nope does not work with the status updates.
1de438c1-48fe-4829-a761-f95004e15755
Tried charging around 21.57 today - charger reports charging; mySkoda App shows I am charging. No flow cards are triggered about this.
Also, although I took it off the charger a few hours ago, drove, plugged it back in to charge and started charging, no values for the Enyaq get updated.
Climatisation is reaching max limit and will not start, “to save the battery. Please drive the car before trying again”. I get this message in the real MySkoda app on the phone.
I have disabled all 3 versions of climatisation in Homey but this still happens.
If I disable the MySkoda app i Homey the problem doesn’t retur after a drive in the car.
If I Enable the MySkoda app in Homey - with or without the climatisation options activated - it will break climatisation again with too many request.
The app in Home Assistant doesn’t have this problem.
This isn’t a New problem. I tried this MySkoda app for Homey for about 6 months ago and also got this problem back then.
@WebLock
Just saw the report and sent you this answer:
Report looks fine, no errors what so ever.
What you can do: enable debug in the device settings and send a new report. It might show some error messages in the logs.
Did you change anything to the force update interval?
Setting it lower than 360 might cause issues on your Car.
Increasing the normal interval might be a good idea too.
I guess it’s not only the climatisation, but the API calls in generic. As the Homey app will only call climatisation whenever the user requests it.
Edit: only difference between the Homey app and Home Assistant integration seems to be that Homey also fetches the temperature and calling the climatisation endpoint to return the temp.
Can you try to trigger climatisation from the Homey app and send a new report after that? (just to see some extra logs)
But have to dive into this why it’s behaving like this. It shouldn’t “wake” the car when it’s only refreshing the data. Only with a force refresh it should do that…
