chose Audi -etron 2021 or newer
thanks
Harald
thanks
Harald
ok sendt, but what about that code I put in clipboard, do you need that?
hell i see other people put it here so:
5d3b68fa-6075-4086-bf88-9aed3a77ad03
thanks
Harald
Hey @Harald_de_Graaf
checked the log.
looks like the car is not added properly. It’s set as the first option (see image)
Can you remove the car and re-add it with the bottom option and see if that resolves the issue?
@Harald_de_Graaf I think I said it wrong… sorry
Can you remove the car and add it again and click the first option Audi
So now i have more info, still no climate controll
Here you go
1800dcc5-8da9-4780-8f0c-6a3372df52c3
Thanks
Harald
@Harald_de_Graaf can you try to change the targetTempeature and then try to start it?
The API responds that it misses some data. If that doesn’t work I’ll dive into the API
Hello again
When targettemp is set, set to 25. next time I check it revert beck to a much lower temp 10
Anyway no climate what so ever
c5dce09f-c945-49cd-8eb8-2db07a030857
Thanks
Harald
Hi @martijnpoppen thanks for making this briljant app!
Would it be possible to add more flow cards for Skoda hybrid in the future? Skoda full electric has a lot more cards to work (play) with, so I’m a bit envious rigth now
If I can do anything to help (send logs for example), please let me know!
My car: Skoda Superb iV hybrid (with Skoda Connect) built in 2020/2021.
Oh wow, that’s a pity! Does the problem lie with the specific type of car or the Skoda Connect app/api? Maybe I should buy a new car, so I can use your app with more cards
Yes it’s model dependent. And also not all EV’s are the same. lots of differences per brand
@Harald_de_Graaf Checked in the API and I think I can make a fix for it. Once i have a update I’ll let you know
Changelog:
- NEW: update library
- FIX: app page support links
- FIX: app page category
Changelog:
Changelog:
- NEW: Skoda V3 support (@Martijn_C FYI )
Changelog:
Thank you very much! Will try it out.
Changelog:
Changelog:
Changelog:
Changelog:
Changelog:
- REVERT: Library Update - Unstable
Changelog:
Changelog:
Changelog:
I get incorrect “charging” status updates for my Skoda.
Example:
