If that’s a question the answer is no
I:
updated the app to 1.22.0
restarted the app
stopped charging (car was charging) with a flow
device still showes “charging = yes (4 months)”
forced refresh
still “charging = yes (4 months)”
switched the device button “start/stop charging” from on to off but that came back to on after a minute or so
charging state still the same
Want another diagnostic and api output?
parody
November 1, 2023, 5:46pm
2092
Here you go! fa3b2d67-9d20-4407-b004-f9797b08cd7b
Correct, new user. Tried to restart the app 5-6 times, 3 days in a row without luck.
@Tobias_Flod then please do a restart and send a diagnostic report after that
@zakraket it was not a question haha. But the charging state should be back. Buttons are still broken as that is still changed in the API
Report will do
You have mail 74c7f169-8da1-4176-95cc-f42ca7f576f5
@zakraket
In your logs I do see that the charging state works…
[log] [Device] A3 - getValue => is_charging => readyForCharging
[log] [Device] A3 - setValue => is_charging => true
Edit: readyForCharging
should produce False. Will check!
@parody I checked the logs.
But I do see the data coming in for those cards so it should be there…
parody
November 1, 2023, 8:06pm
2100
Well that is odd!
I decided to remove all the cars, installed the test version of your app you just posted and rebooted my Homey. Like magic it is now there when I re-added just the one (new) car. I’m not sure which one of those things fixed it, but it now appears to be working!
Thanks again!
OH2TH
November 2, 2023, 5:45am
2102
Question of this measurement’s label
If that is the rate of charge as range kilometers per hour, should that the be km/h?
km p/h would be km per per hour
7b7a63d4-3577-447c-8962-e8fcbbb9cd18
@Tobias_Flod I see that during restart these options were added:
'is_plug_connected',
'measure_remaining_charge_time',
'is_climating'
So i guess everything is in order now
Climate, but not is plug connected.
Strange, restarted it once more and now everything looks OK. Thank you!
Missed this update last night, but I just noticed my “charging state” is updated againand version is now 1.22.1… Superb!
Installation and a first test with Audi Q5 tfsi e seems ok
Hi Martijn,
When will the notification voor doors and windows added?
