No flow card for it, no. In fact there are a lot fewer cards compared to the GTE.
@zakraket the Audi API has updated again, so will look into that.
Does the app work for you at the moment? Which version are you running
@parody should be there, can you restart the app? The app will determine flowcards on app start
I only use the app to charge my audi when there is enough solar (with several flows) but that works. To be honest; it - my set of flows - didn’t work for the last 4 months, but last week I noticed that the only reason that it did not work was because my flows test for the “charging state”, and that was the only parameter that does not update a.t.m.
So when I reconfigured some flows it now works again, only some flows start when not needed because I’m missing this parameter.
I’m using v1.21.0 (experimental) on a Audi A3 etron (hybrid)
Will have a look at that @zakraket when the issues are resolved again. Can you share a report with debug enabled? then i can look into that when needed
I hope this is what you mean… Also sent a diagreport
(Btw, charging time does also not update correctly; it updates but f.e. now says 15mins left while battery is full. I don’t mind because I don’t really need that)
"info": {
"connection": false
"x": {
"general": {
I tried that but sadly no luck. This is what is listed using the electric/pre2020 option:
And this is using the hybrid option (which finds the car even though it is not hybrid):
While the hybrid GTE has a few more including the illusive…
@zakraket yep i see, already got your data in the report. Will make a fix
PS: remove you VIN
@parody can you send a diagnostic report?
@zakraket maybe also the lon and lat numbers
we can now see that you live in Brabant…
@parody can you do a app restart and after 2 minutes send a diagnostic report?
Hi Martijn,
I have the 1.21. installed, redesigned the Q8 e-tron. I left the poll frequency at 5 minutes. The Audi server no longer blocks my connect account after a series of Homey accesses. That’s good.
Unfortunately, a number of commands are not executed or the display in the Q8 device is completely missing.
I cannot start/stop the air conditioning and ventilation or set a temperature.
“Remaining climate time” is not displayed and cannot be used in the flow. The “Connected” parameter is not displayed.
In the Audi app and in the vehicle there is a “Charge Target” once for the home position and once for the rest of the world. Your app will only show “Charge Target” for the rest of the world.
Thank you very much for your great and always quick support.
@Tregobad I didn’t fix anything on the commands yet, as said yesterday.
This was only fixing the Audi API so the app can be back alive again
I’ll have a look at that soon.
For the missing parameters, please restart the app, most of the time that fixes these issues
maybe a bit off topic but until november 8th the we connect plus subscription seems to be €30 off in the Netherlands.
if it would only be stable for longer than a day…
Sure, here you go! fd708d34-7ac9-4ae1-b9be-4b6d0cd386e0
@parody seems like 2 minutes was too long. can you restart the app and immediately send a report?
Is there a setup I need to do to get the marked flow cards?
Missing plug is connected and is climatisation on…
@Tobias_Flod are you a new user? Try a app restart most of the time that will add all flow cards.
New app update ( TEST: 1.22.0)
Changelog:
- NEW: Api update
- NEW: Italian Translation (Big thanks to @xazac )
- FIX: isCharging
- NEW: rewrite lock/unlock to new API
Changelog:
- NEW: Api update
- FIX: isCharging
Changelog:
- NEW: Api update
- FIX: isCharging
Changelog:
- NEW: Api update
- FIX: isCharging
Changelog:
- NEW: Api update
- FIX: isCharging
More - apps - AppName - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the TEST version by clicking the link above and press install
Don’t want to be part of this TEST version? Install the LIVE version →
@zakraket is Charging is back
