[APP][Pro] Ubiquiti UniFi Protect
I’m thinking to buy Unifi doorbell G4 Pro… will the finger print works with homey?
AFAIK the fingerprint reader isnt enabled at all atm.
Anyone able to sync the cameras to homekit using the experimental homekit sync? I get the cameras into Homekit but no image
Any news here? My G4 detection is not working anymore.
Hopefully @ObelixNL will have time to add support for the chime (so you can for example mute it at night) and G4 Pro doorbell :grinning:
I don’t have the chime and doorbell pro so i can’t test or create support for the chime and pro doorbell.
What could be wrong? My Ubiquiti UniFi Network app has a connected status but Unifi Protect doesn’t seem to connect and i can’t see or figure out why. Any suggestions?
Same issue… no updates yet? :frowning:
Since a few days, option Set Recording Mode doesn’t respond on a brand new HP23.
When the option Recording is turned of in the Unifi environment it is responding only with a terrible long pauze within it.
Where do you change the unifi os? I can only change ip/port & user/pwd
You can’t change Unifi OS anymore, we support only UniFi OS.
I will test this later this week
Hi Stéphan! @ObelixNL
When the app was updated to 1.5.17 last night, it affected all flows that contained ‘Set recording mode…’.
All ‘Set recording mode…’ became ‘Card Unavailable’.
Restarted the app and Homey without result.
However, it is possible to add ‘Set recording mode…’ again to each flow - it will just be a bit of work to recreate…
You are testing the test version? I have published 1.5.18 with the old action cards. i have created new action cards and make the doorbell as is own device type.
Now it’s working again! Thnx!
i have created it from information from internet, i can’t test the integration with the chime. When i have the new icons for the device i will publish an new test version with chime support.
FYI i just discovered that a unifi update recently reset the permissions for my homey user on unifi. Homey did not have permissions to ser att Protect devices anymore due to the new “roles” on the unifi side.
Check this if you have protect issues in homey!
Thanks for mentioning this important change.
My post above is solved.
you’re my hero of the day
Im having issus getting the “a doorbell ringing” to trigger.
I have the homey pro23 and snapshots work from the camera.
Running the latest version of the app.
Any idea?
Since a few weeks the if ‘a smart detection event’ don’t work/trigger anymore.
Camera’s/snapshots are visible, app restarts every night with a flow. But when I open the camera I don’t see the smart detection tile with the timestamp, I thought it was there in the past (and probably the trigger for the smart detection event).
Are there more people experiencing this? And is there a solution?
