[APP][Pro] Tuya Cloud - This app allows you to connect Homey to the Tuya cloud
Hi Jurgen, I sent you a report with this id:
8393b8be-7fb5-400a-8b1d-ed33d086531d
The app noticed an alarm once, but did not detect the sensor was closed. Hope the report will give you some info. If you need extra info, please let me know. Thanks Jurgen!!!
Hello! Is it possible to add “Nedis - Smart IR” to the Tuya Cloud app in Homey?
I have it added in the standalone Tuya app but I can’t add it to Homey.
Need it to control my Mitsubishi AC because Homey doesn’t have support for Mitsubishi (IR)
Thanks, Kim
Sensibo would make more sense, and is supported.
It’s already there. Use the tap-to-run method.
I use it to control (older) devices (amps, TV sets, Cable TV box) with IR.
@friethoe, I don’t see messages coming from Tuya, but I see the following error:
[log] 2022-07-02 19:36:36 [TuyaCloudApp] TuyaOpenAPI response: {“code”:28841101,“msg”:“No permissions. This API is not subscribed.”,“success”:false,“t”:xxxxxxxxxxxx,“tid”:“zzzzzzzzzzzzz”} path = /v1.0/iot-03/open-hub/access-config
So I think you don’t have added all the api’s of point 6 of the manual: Tuya IoT Platform Configuration Guide Using Smart Home PaaS · tuya/tuya-homebridge Wiki (github.com)
@Jurgen_Heine hi Jurgen, I just sent you an updated log, now with more info, i hope.
Id of the log:
bf2f9f49-d7e2-4e4e-93db-d34f702cbe3b
Jurgen, it seems to work now! The sensor reports the right status in the device screen of Homey. But now I noticed that when I switch a lamp on, the icon in the device screen in Homey will light up and off again. The lamp is switched on, but cannot be switched off again via the device screen. I can via the android tuya app.
Update: please ignore the issue with the state in the device screen. That is resolved by deleting the device and added it again. All works awsome and amazing how fast it works!!!
@Jurgen_Heine Awsome Jurgen!!! Thank you for your great app and support!!!
Good to hear it’s working now
Veeeeery nice, Jurgen! Thanks!
Installed test version 1.1.0 and it works here.
I’ve got a wifi-2-IR transmitter, but this doesn’t work (yet).
The created IR devices are present in iot cloud environment.
But they can only be used via tap-to-run scenes.
Not an issue to me, but just for your information.
~Peter
Hi Jurgen,
I created the same ticket in the git repo as well, but to let the fellow community help out I thought this might be a better spot.
I happened to find out about your app looking for a potential solution to control my IKOHS fan via my homey. However via the app itself I do not get the possiblity to add such a device. Clicking on any of the other (legacy) device available just provides a “there is no device available” error.
I stumbled on this project which allowed me to control it by python currently.
I’m talking about these fans.
Would it be possible to create support for such a thing and or could I help with making it compatible with the app?
In the meantime I did try to create scene’s as well in the hope that those would be integrated without a device being “supported” but unfortunately they are not in the list.
kind regards,
Rik
Important Note - In the meantime I was aable to select legacy scene’s to trigger from the homey! So it seems like I can actually assign tasks to the fan.
Still just no support for adding the direct devices, as far as I am aware atleast.
When adding a device is not possible, try using the so called RAW Commands functionality.
Howto:
-With the flow below, you´ll be able to “listen” to event messages of your devices;
In this example a message of the ‘text’ type, which will return text, numeric and yes/no values.
So, when you trigger the device you want to control from the Tuya Smart mobile app (Google store / Apple store), or the SmartLife mobile app (Google store / Apple store)
or when you just activate a sensor,
you’ll catch the device ID, function name and function value events, which you’ll need to trigger flows like you want them to, or to control the Tuya devices you had in mind:
Examples of how to control Homey devices with Tuya events triggers
Example of how to control Tuya devices by sending Tuya commands
Well, when all this doesn’t make much sense to you, please try the alternative:
tap-to-run scene method !
Hoe Tuya Smart/Tuya cloud koppelen met Homey
Need some help with Tuya API that requires signature authentication
LSC (Action) moodlight
Google home assistent ziet geen flow van homey
Tuya cloud Ir afstandsbedieningen
Are Tuya/Smartlife blinds a waste of time to try to integrate with Homey Pro?
Fan/lamp
Newbie help to compatible units
Energiemeter met 16 spoelen (ervaring gezocht)
Help, Tuya Cloud geeft foutmelding
LSC Floodlight (Action)(Tuya)
Nedis WiFi Smart plug and NedisÂŽ SmartLife
LANBON Devices
Inventor airconditioning aan Homey toevoegen
Tuya cloud Error: Error: Code: 2009; msg: not support this device
Merkwaardige issues sinds overstap van homey 2018 naar homey pro 2023 en ziggo naar KPN in relatie tot google integratie
Gosund SP111 WiFi Plug
Have your coffee ready when you wake up?
Luminea Home Control Aufputz Steckdose: Outdoor-WLAN-Aufputz-Doppelsteckdose
[Request] Full DP Instruction Support for Tuya Air Conditioner (2.6KW)
[APP][Pro] Duux - Take full control of your indoor air quality
Suche Smartplug mit 2x USB
Hombli
TauschbĂśrse
Raam / Deur Sensor van Tuya in Homey
Error melding bij knop ID bij Tuya schakelaar
Aqara FP2, mmWave presence detection on WiFi
Is there anyone who is working on, or aware off, an app to make any mmWave presence sensor available
[APP][Pro] Homematic App - Connect Homematic with Homey
Device request: Magnum Heating MRC wifi Thermostat
Duux stops support for Homey
The Flow Exchange(r) - Exchange Your Flows with Others!
Share Your Device! - Advanced Virtual Devices from Device Capabilities
LSC lampen koppelen
Tuya zonneschermen ‘bewegen’ niet?
Nedis app
VOCOlinc App or systems to dedicated correctly detect all VOCOlinc devices
Tuya wifi thermostaat koppelen met meerder schakelaars hoe
Digitale kamer thermostaat
Nedis Zigbee Smart Radiator Thermostat - how to connect
[APP][Pro] Broadlink App
Moes smart knob
LSC (Action) verdeeldoos in Homey
Let Homey start something via Google Home
Hi Peter,
No worries fellow dutchman here.
I created the following flow similar to yours:
However triggering anything in the smart life app does not create an event or push notification. However I’m not sure whether thats because the events is not received or because the configuration of the app is not working properly.
When trying to add any device I get the following screen:
When trying to setup the app (since the update to expiremental) after pressing save I get the error code: “Error: Code: 2406, msg: skill id invalid”
It means you entered a Data center for another region.
For NL, “Data center” should be set to Central Europe (Tuya Smart Developer Center)
Screenshot from 2022-07-06 18-18-36
That is because the app is not yet configured right, and not connected to the iot cloud
HI,
I have been having troubles adding my motion sensors from Smart life to Homey. I can add the legacy devices but not the original devices. When I try to add the motion sensor it gives the error “Please configure your app first.” I have configured everything and I can only add legacy devices.
Does someone know how to fix this? See pictures.
Please start by reading post #1 and use the smartphone app Tuya Smart instead of SmartLife
I get the error message in the Tuya cloud app
"error;code;1004;msg sign invalid
(ook voor Homey dus :wink: )
The cloud setup is working.
Tap to run is working in the local Tyua app.
The flow is selectable in homey but unfortunately the fan is not responding
fan
Legacy = ending
Try the “execute a scene” card instead.
Hello Peter,
Then i get an error and no scene is selectable
