Hoe heb je de Egde aan de Tuya app gekregen?
Ik krijg t met geen enkele mogelijkheid voor elkaar het is wel een 2000 ipv jouw 1500)…
Ik heb de gen2 die alleen met de nieuwe Duux app werkt.
How did you manage to add the Edge to the Tuya app?
I cannot connect it with every possible way I tried, but I have the 2000 insted of your 1500.
I have the gen2 that only works with the new Duux app.
Translated answer:
First reset the Edge itself, and then start the Tuya app on your mobile, register and add the Edge in Tuya (this will be automatic through wifi) - + Add Device Heater. If it is connected in the app, you can follow the procedure for Homey.
Follow this link for further instructions.
PS. I have a Gen1 that works with the older Duux app. So I don’t know if that is the problem.
