[APP][Pro] Duux Gen2
Control the newer Duux devices with Homey.
If your device isn’t supported, please reply here or send a DM so I can add support for it.
I’m looking for users with the following Duux products:
  • Duux Edge
  • Duux North
  • Duux Beam (Mini or 2)
If you have any of these devices, please send a configuration report. You can send a report this way:
  1. First, add any other device in the list and log in to your account
  2. When the screen “No new devices have been found” appears, go to the Settings (More→Settings→Duux Gen2)
  3. In the settings, get the configuration and send it privately. You can use the “Send” feature to send the report privately or you can send a DM and share the configuration that way.
Device Support
Note that this app only works with Duux Gen2 devices (the new “Duux” mobile app with the Google Home/Alexa support). If your Duux Gen2 device isn’t detected or is missing from the list, you can request support in this forum topic.
Version 1.0.1
  • Added Homey Community Forum topic ID to the app manifest
Version 1.0.2
  • Small bugfix and increase polling time
Hi @smarthomesven ,
Zou je ook de Duux Threesixty 2 kunnen toevoegen?
Dat zou echt top zijn!
Groet, Joey
+1 for the Duux Threesixty 2.
I know there’s a lot of these things around so would be awesome add compatibility for this. I’d be happy to donate for a beer or a cake :wink:
Version 1.0.3
  • Added settings page
I’'ve just added the Duux Threesixty to the test version of the app. Please let me know if it’s working.
If you encounter any issues or want me to add support for another device, please let me know.
Version 1.1.1
  • Fix threesixty
Version 1.1.2
  • Fix issues
Version 1.1.3
  • Fix typo in fan speed command for Threesixty
Version 1.1.4
  • Fixed set fan speed Flow card issue for the Threesixty
Version 1.1.7
  • Added an option to easily send the configurations privately
Can you also add the Whisper flex? It doesn’t work with the old Homey app.
Can you also add the Edge 2000 gen2 electric heater, not the oil version?
It will be great if you also can integrate the ECO mode for this.
Not all remotes (like mine) have the button on the remote for the ECO mode.
Thanks in advance!
Version 1.2.1
  • Added support for the Whisper Flex
The Threesixty is already supported
Let me know if you encounter any issues
Thanks for your work on this!
I just tried adding it. It appears in the Debug menu (“successfully loaded data from 1 device”) and all of its information displays correctly. However, when I attempt to add it to Homey Pro, it says “no new devices have been found.” Seems there might be bug.
I’ve sent the debug logs via the Homey app. Debug ID: 09e09520-0cb5-4365-9494-59b98b4fe7b5
It seems like your Threesixty uses a different device type ID. I will add it to the app now
