[APP][Pro] Meross - Simple Devices, Simplify Your Life
Yes I tried the Light device did not work.
Thank you for the Info. I well wait for the new update.
Will it also be supported on Pro 2019?
It sure will! The whole shebang :wink:
Meross did provide me with an OAuth API which will be used for Homey Cloud, since at the moment it only supports garage door openers and thermostats.
For Homey Pro I’m working on an API which combines the local HTTP and cloud MQTT connections Meross “offers” to support basically any device Meross has released.
@Doekse — really appreciate the work on the Cloud API integration! Wanted to add a vote for garage door opener (MSG100/MSG200) support, and flag two UX issues I’ve hit using the Community app’s garage door driver that’d be great to avoid if you’re building this fresh:
  1. Quick action toggle polarity: currently the button highlights as “on” when the door is closed — counterintuitive. Would suggest “on” = open, “off” = closed.
  2. Status text clarity: currently shows “Yes/No” (Yes = closed, No = open), which isn’t self-explanatory. “Open/Closed” text would be much clearer, especially for other household members glancing at the app.
Happy to help test once there’s a build to try. Thanks for all the effort on this!
I’m looking for a garage door controller for my Homey Pro.
Homey’s Best Buy Guide recommends the Meross MSG200:
However, when I install the official Meross app and choose Add Device, neither the MSG100 nor the MSG200 appears in the list of supported devices.
Am I missing something?
  • Which Homey app is supposed to support the MSG100/MSG200?
  • Is the Best Buy Guide outdated?
  • Does the official app support these devices at all?
I’d like a proper garage door device in Homey (open/close + status), not just a relay with separate flows.
Hello, yes i have the same situation, you must install these meross app as well… Meross | Homey
Currently i use both Meross Apps, the official app for the motion sensors and the community app for the garage door opener.
Starting to sound a bit like a broken record here, but I hope to finish the Meross API layer after my vacation. I’m doing this in my spare time so please bear with me!
ISSUE REPORT — Meross Official App (Homey Pro 2026) • My Meross MS605 is not a Matter device, yet both Homey and my iPhone still initiate a Matter pairing process. • The Meross app on Homey does not display any login screen. • The app only shows: Enabled, Automatic Update, Restart, Diagnostic Report, Uninstall. • There is no option to log in with my Meross account. • As a result, the Meross cloud does not synchronize, and the MS605 does not appear in Homey Devices. • I have removed the app five times, performed a cold boot (Homey unplugged for 1 minute), and reinstalled it via the App Store — but the login module never appears. • Insights still shows CPU/RAM, but this is old data; the app is truly removed. • The Meross app appears to be stuck in a “half‑installed” state, where the cloud token and login module are not being loaded.
Or read the first post there which explains your issue.
Andy
I cannot change it :frowning:
There isn’t a non-Matter version of the MS605? It only comes in a Matter over Thread version :thinking:
The Meross app for Homey currently only supports Matter devices, that’s the reason you won’t find a way to log in. Support for non-Matter devices and Matter-over-Wi-Fi devices that are accessible through the Meross cloud/app is currently being worked on.
However, the MS605 itself will always connect via Matter over Thread and therefore requires a Thread Border Router, such as Homey Pro, to function.
Yes i can confirm the explanation from Doekse, i have many MS605 pecisions sensor in my home working and all are teached directly into the Thread network too Homey pro 2026 with the existing official homey app…
Hi all! Over the past little while, I’ve spent quite some time working on the node-meross-sdk, which will be used by the Meross app for Homey to add support for non-Matter devices.
The first device type I’ll be supporting is Smart Plugs, basically everything listed under the Smart Plug section in the Meross mobile app.
For those of you using these products, I’ll need your help testing the different plugs to make sure everything works as expected.
I’m hoping to launch a first version this weekend. Keep y’all posted! :smile:
Hi
I have a question.
I bought an Meross mrs105 shutter switch. Installing all went good and controlling the shutter with the device button in homey works without any issues..
but when I make a flow it goes wrong;
Just easy ; when time is 22:00, then close shutter, it sometimes works but mostly it doesn’t! When I press the start flow button or the device button in Homey it closes without any problems.
what can be wrong, and what can I do to solve this?
Hope to hear!
Will this also support the Matter-enabled devices to connect to Pro 2019 (which doesn’t have Matter built in)? And how often does the energy monitoring update?
It will! The SDK is TypeScript-based and will support all devices that can also be used in the Meross mobile app.
Devices will communicate either via MQTT through the cloud or via local HTTP if Homey can reach the device locally, which will most likely be the case.
For local HTTP, I currently have polling for power, voltage and amperage set to every 30 seconds. I’d like to make that quicker if possible, but that will need some testing to see how the devices handle it.
All in all, it has been running very stable for the last couple of days. I’m currently just waiting for the device icons before I can push the first version.
Below some screenshots of one of my MSS315 Matter Smart Plugs connected via the SDK:
My device would probably not be reachable via LAN because of the network security that’s in place. Is MQTT also every 30 seconds, or does that update more quickly?
For cloud MQTT, Meross has some pretty strict rate limits, and exceeding them can actually get you kicked off your account.
When using cloud MQTT, power, voltage and amperage will therefore be polled at most once every 180 seconds. There’s also a limit of 5 outbound calls per 91 seconds. So if you control the device frequently, polling may occasionally be delayed because of that.
I did also get access to a dedicated OAuth-based API from Meross for our integration, but unfortunately that currently only supports garage door openers and thermostats.
Hi everyone, I’m happy to announce the test release of version 3.0.0 of the Meross app for Homey!
This update introduces the new node-meross-sdk and adds support for Smart Plugs, Smart Outdoor Plugs, Smart Surge Protectors, and Smart Switches across all Homey Pro models running version 13.0.0 or later.
Version 3.0.0 will remain in testing for a while so I can monitor how different devices perform with the new library. Before getting started, please read the first post in this thread for answers to frequently asked questions.
Happy testing!
