Hi
Can some kind developer please write an app for Meross garageportopener, thank you in advance
Did you already search this forum for meross?
Yes, only found an alpha app, nothing usefull
Nothing about garage door stuff indeed
Try the integration through SmartThings. I have all of my Meross devices on Homey thanks to SmartThings.
You have first to add your devices on SmartThings app on your cellphone, and after that install the dedicated SmartThings app on Homey.
That sounds like a great idea, only problem is that i cant find the Smarthings App in Homey
Hi again
Downloaded the app from community store but i cant find my garagedoor from the homeyapp.
I have added the garagedoor in the regular smartThings app, any ideas?
Hi again, ofcourse i have configured the app with token and More. Other smartthing devices arr showing but not my Meross garagedoor
Maybe it has to be activated ones?
Hi @Carlssof,
it is possible that not all the Meross devices are supported by SmartThings app.
I have only smart plugs and power strips (5 pcs., 3 different Meross models) and all of them are supported by SmartThings (and Homey with SmartThings app).
Possible, been trying to gel in contact with the developer of Smartthings to Homey but cant find any forms to do so
Hi @Carlssof,
Can you try to add the device (even though it won’t be found) as that will populate a log. If you then go to the Apps - Configure App and tap on the Detected tab, you should see a list of devices that hopefully gives me the information i need to add support for new things. If you could copy that list and send it to me via a PM I will se what I can do.
Have you enabled the remote control feature on the washing machine?
Are you using the latest version of the app?
Could you open More > Apps > SmartThings > Configure App and select the Log tab. Then enabled the log (blue tick).
Next run the flow and wait for it to show the error. Finally go back to the Log tab and copy the contents to a PM. Hopefully that will give me an idea of what is failing.
Hi again
My garageport has stopped working, i am getting an https error, please see the log below
Setting logEnabled has changed.
* !!!!!! Polling started
* devices/b8a274f2-c4e7-47a9-bb32-aadbc697147b/components/main/capabilities/doorControl/status
* Get device: devices/b8a274f2-c4e7-47a9-bb32-aadbc697147b/components/main/capabilities/doorControl/status
Result: {
"door": {
"value": "open",
"timestamp": "2021-12-11T17:53:28.676Z"
* Set Capability: alarm_garage_door - Value: true
* Trigger Check: alarm_garage_door = true was true
* !!!!!! Polling finished
* Next Interval = 5000
Result: {
"door": {
"value": "open",
* door_action: arg = close - state = [object Object]
* PostURL url: devices/b8a274f2-c4e7-47a9-bb32-aadbc697147b/commands
* PostUrl body: {"commands":[{"component":"main","capability":"doorControl","command":"close","arguments":[]}]}
* HTTPS Error: 424:
* Garageport onCapabilityGarageDoor_set Error undefined
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
* HTTPS Error: 424:
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Result: {
"door": {
"value": "open",
Mobila hälsningar
Fredrik Carlsson
Error 424 means it failed because a dependency failed.
Have you tried rebooting your SmartThings hub?
Yes, any other ideas?
Mobila hälsningar
Fredrik Carlsson
