[APP][Pro] Homewizard 🧙‍♂️
Strange it works fine for me. Policy mode is enabled and SlimLaden mode from Homewizard is not enabled?
Can you explain what you mean by that? I’m not quite sure…
This is my setting in HW
That explains, my app doesnt control your battery so planning is disabled.
You have Homewizard SlimLaden in charge and I dont have access to their planning.
Im sorry, then I misunderstood its use. Its based on your planning and I see the settings in the app now. Sorry for the confusion.
Is there a difference with the HW policy?
Thanks, that’s a really interesting suggestion!
I’m particularly interested in retrieving the ambient temperature from my HomeWizard Energy Displays and making it available in Homey Pro.
Have you actually managed to retrieve the temperature through the reverse-engineered cloud API, or is this currently based on the Android app’s data model?
If you’ve tested it, could you point me towards the relevant GitHub repository, endpoint or implementation? I’m also curious about the update frequency and whether authentication is relatively straightforward.
Thanks for the suggestion!
Best regards, Jan
Hi Jeroen,
Thanks for your quick response and clarification!
That’s unfortunate, but I fully understand your position. I appreciate that you prefer to work with officially supported and proven APIs rather than relying on reverse-engineered solutions that might introduce reliability or maintenance issues.
The upcoming temperature/humidity device certainly sounds interesting and might offer a good alternative.
Best regards, Jan
Yes there is a difference but I don’t know on exact details what Homewizard does in their policy.
They both cater for weather, pv forecast and prices. The only difference might be neighborhood related. I dont have those sources to watch/monitor if voltages are an issue or not.
Further we might have different sources for weather or solar forecast. I am using OpenMeteo and KNMI for various sources on wind, cloud coverage and meteosat for short term adjustments (0-2h).
Most other implementations rely on Solcast which sadly is rate limited for 10 queries a day.
The other difference is cloud driven or locally on our Homey.
@Jeroen_Tebbens can you check my PR?
The device has been released now
Sure, when I get my hands on one of them to verify/test and make it available.
By popular demand, HW display temperature and humidity are now in version v3.19.11. The new thermometer will follow when I can verify it with the hardware.
AFAIK the display does not have a humidity measurement though. Or maybe there’s a newer generation?
It does, verified + working.
Great! Thanks for adding the Energy Display! I have two of them, and both are working well.
Hi Jeroen,
I’m using a websocket 2 seconds update interval for my homewizard P1 meter (apiv2). I noticed that the value for the average_power_15m_w (15 minutes power value) only updates every ~30 seconds though, while other values are updated more frequently. Is this limited by the homewizard app, or by the P1 meter or by the actual digital meter only sending that value every 30 seconds instead of every 2 seconds? Any possibility to have this value updated more frequently?
Steven
Yes I’ve set this in the section to be updated every 30s to slim down the overhead inside the driver.
I am not aware what the update interval for P1 itself is as the name hints its a 15min average so estimated real time would not be necessary and a 30s interval would be fine.
I have nothing to verify as we have nothing here in the Netherlands on this as this is purely a Belgium thing.
    // Low-frequency capabilities: update every 30 seconds
    const lowFreqCapabilities = {
      'meter_power.consumed': m.energy_import_kwh,
      'meter_power.returned': m.energy_export_kwh,
      'meter_power.consumed.t1': m.energy_import_t1_kwh,
      'meter_power.produced.t1': m.energy_export_t1_kwh,
      'meter_power.consumed.t2': m.energy_import_t2_kwh,
      'meter_power.produced.t2': m.energy_export_t2_kwh,
      'meter_power.consumed.t3': m.energy_import_t3_kwh,
      'meter_power.produced.t3': m.energy_export_t3_kwh,
      'meter_power.consumed.t4': m.energy_import_t4_kwh,
      'meter_power.produced.t4': m.energy_export_t4_kwh,
      'measure_power.montly_power_peak': m.monthly_power_peak_w,
      'measure_power.average_power_15m_w': m.average_power_15m_w,
Hi Jeroen, I meanwhile found out - via the API v1 URL - that the meter/P1 updates this value continuously. An example graph of this value is shown below. I use this value to switch on my plugin battery as soon as the 2500 Watt in 15 minutes timeframe is nearly reached. This 2500 watt is the minimal peak which is charged to Belgian customers, everything used above this minimal peak is charged additionally.
In a 30 second interval, this value can change quite a lot though. This is why I was looking to have this value updated more frequently in order to stay closer to this 2500 watt. I now found a way to do this using the API v1 and homeyscript, but if this could be a setting in the homewizard app, I would no longer need this alternative approach.
Ok let me move it to the realtime section.
v3.20.5 (test)
  • Several bug fixes for Battery Policy
  • User request on Belgium P1 (m.average_power_15m_w) interval changed from 30s to real time
  • Added phase imbalance indicator capability to trigger / flow when there is a 3 phased household has an imbalanced phases)
  • mDNS fix when you want to revert from static ip settings
  • P1 Energy dongle (apiv1), gasmeter fix current usage not updating properly
v3.20.5 now live.
Next test releases will be dropping “salderen” code completely.
If you still are on Battery Policy and like to stick to salderen then use the production version.
Just reinstall the normal app link from the Store and not the /test behind the url.
Ik heb wat problemen met de cloudkoppeling van P1 meter.
De homewizard app geeft een hogere Totale KWh aan dan hetgeen dat aan homey wordt doorgegeven.
Ik maak gebruik van de P1 cloudkoppeling.
