[APP][Pro] Homewizard 🧙‍♂️
done and diag sended
now your sockets show as 10s/15s let me fix that and put extra checks in to actively log the change and restart of the interval. Review sockets, update to 4s and restart the app. That should make your 3 device all update at an interval of 4s. I will push a new (test) version later.
I have to be careful with these drivers as there are 20000+ energy sockets using it. Fixing one problem (yours) create another bigger one if not carefully checked.
EDIT: v3.17.9 (testing)
All sockets and P1 on 4 sec and app restarted
Great, now review/test your flow and see if the behavior you expect is restored.
Other suggestion, there are cards added recently by Athom that check on “vermogen” = watts for a period of time x seconds
Must I install version 3.17.9 now?
Must? No. You can try if you like. I force nobody. Moreover I barely have time to help everyone at this moment. Apart from not many really cares about latest additions done last few months which drains my enthusiasm,
Sorry for the delay, drop me a diagnostic but I doubt if its the app as this portion hardly changed since 2023.
At first sight, it looks that the other problem (stable regulation for heating boiler) is ok again.
Many thanks for your help!
You’re welcome :+1:
faefb843-e357-4e63-ab3a-04ed89eb3241
diag after allon 4 sec
yes 4s all
Your work is highly appreciated, but I have no Battery so I can not comment about the modifications you made to integrate the homewizard battery.
Many thanks for resolving the problems with the energy sockets (are they a result of modifications for the battery?).
No if your scroll back this forum topic there were earlier problems with users that have like 20x sockets in their house making the app go crazy on CPU / Memory usage and crashing all the time. So hence interval tuning, delaying startup every 500ms to spread the load rather having 20x at the same time. As I say this app supports a very large user base. Batteries are around 2000+ if I got the numbers right. With a lot of EMS apps in the store lately. I can’t do nothing of course, yet these apps use “root-like” priveleges to control your whole homey which I don’t like but it does impact my app as I see odd cases where the app traces modes/states of devices that code changed outside the app and then complain at my app it isnt working…
I tried v3.17.9 and polling interval of energy socket does not change after modifying in advanced settings…
So back to v3.17.3.
Hi Jeroen. Yesterday I first installed the P1 and batteries en later changed them to websocket, now it seems they have a more reliable connection.
I am trying to add existing HW sockets to Homey. Weirdly when I want to add a socket the app says there are no sockets found (I have multiple, all on the same network).
I restarted the app and Homey but no difference yet. Also the production version of the app gave the same result.
Normally it should find sockets and I would have to press the button, correct?
Nope, no need to press button, that will trigger de adhoc wifi of the socket and homey will not find it. The only exception is the P1 and PIB as these are APIv2 mode and only they require a button pressed.
Fixed now in v3.17.10 (test)
Oké, I have multiple sockets and not pressed button, there is no list of sockets in the app when adding. Also API is switched on (are not changed, I only removed them from Homey). Uhh, weird, adding the P1 and batteries worked like a charm. Any thoughts?
Then your sockets are somehow connected to an accesspoint that doesnt handle the mDNS (Apple Bonjour protocol) properly. You can give your access-point a reboot to get this back active (many user had this before - see history of this topic). First topic also hints on a mDNS browser/discovery tool to see if these sockets are visible or not.
This is beyond me and this app. This app ask Homey for mDNS discovery results and if your Homey has no information on this then I cant show them either. While it worked for your P1 and/or batteries (different AP?) I don’t know / can’t tell as I have no knowledge of your wifi set up.
IoT Vlan? Guest network? Homey in different network than your sockets? So many variables that can make it fail.
I have been thinking back in time for what is changed in my network, eg new formware Ziggo modem, and, a new NAS. I just switched it off and the discovery works again. When installing the NAS the sockets were allready in Homey.
Thank you for giving me a heads up and an idea for looking.
I am thinking of adding a seperate 2.4ghz network with a Unify network with new AP’s and switching of 2.4 in Ziggo.
In the Ziggo router settings and in the cabled wifi Pods everything is shown as oké but isn’t. It’s not visible for me.
