[APP][Pro] Homewizard 🧙‍♂️
even weer boven de 20% cpu: c0ed7c62-df3e-4eb6-b489-1c898fb3c9a6, nog geen crash
what longer on 20, just before crash: 78504f4d-bf01-4867-8fe4-e07d53a4e036
around feb 15 the cpu usage goes up, perhaps an update at that time? I will think if I changed something, don’t know now
I have some time ago installed the the new app, battery policy…and removed to look at later on. Now installed it again, not configured and cpu usage drops…keeps going up and down though
no crashes up till now
Update 18:03
After work by Jeroen the problem the app crashing is solved, CPU went down al lot and shows now a normal usage. @Jeroen_Tebbens THANKS!
v3.13.49 (test/beta)
  • WebSocket internals refactored; debug and runtime statistics are now surfaced in the settings page for improved diagnostics
Good morning, the rate is now 0.367 and the batteries are on ‘standby’ because the app advises this (screenshot 1). But the explanation that follows (screenshot 2) is that the battery should have been set to ‘discharged’ by now (I agree on that :slight_smile: )..
Is something going wrong, or am I reading it wrong?
Yes I understand your response need to improve it.
It prompts a collection of reasons all with a certain weight/value per reason. Then it does the additions and subtractions of that and that becomes the action. In this case standby. The idea is to delay the battery charge a little as sun prod will return to grid with a price of 0.367 (profit). While the solar production later still is able to charge anyway when prices are lower than that. Need to see how I improve the reasoning in that view.
On the other hand I see you still have battery left so it would also make sense to discharge with 0.367. I’ve not come across this condition myself yet as my battery is always empty in the morning. So yes need more investigation on this. Thanks for sharing. Still an early feature in this app.
EDIT: try v3.13.55 (test/beta)
Ah thx for the clear explanation. Yes early this morning the sun was not strong enough (20W) to charge the batteries or even the house consumption itself, but with 46% remaining battery capacity it would be great to use that to power the house (300-400W) instead of taking it from the grid (at € 0,367).
I installed the new test version and will report back if any interesting is happening. Thx for the effort so far :+1:t2:
No problem, still tuning this myself so it isnt perfect yet. As said I only have 1 battery unit which already is empty around midnight. Your set up has 2 units so certain condition hit later or not at all. So thanks for sharing your feedback as this will help the code and the other users.
Another interesting case: the app thinks there is enough solar to power the house and stays on ‘zero_charge_only’. But it is raining and so no solar power. The price is €0,36 and the batteries are at 58% and the Battery Policy shows ‘ontladen (discharging)’ → hence they are not and remain ‘idle’. The time is 17:35.
I thought I had this fixed in v3.13.55
Indeed interesting. The comment is wrong as it uses the recommended text and not the actioned text.
Secondly I capture 15min prices the actions are against hourly average so they don’t align.
This one (15m vs 1 hour) is hard still how to cope with this properly.
Pushed new test version v3.13.57
  • Recommended mode fix text and when leftover battery during high price morning → discharge
  • Fix for to_full when PV is not enough to charge battery and prices are lowest
ik heb sinds enkele dagen het probleem dat de app meermaals per dag crasht. Dit is zowel bij de test als reguliere app. Ik heb hiervoor een diagnostic report gemaakt. Hebben jullie hier ook last van? Hoe los ik dit oP.
Alvast bedankt
English here (please translate your question or move it to dutch section)…but.
You seem to have configured flow cards that fire nearly every second maybe check that as that made the app crash:
stdout:
    2026-03-11T19:16:45.099Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:16:45.099Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:16:45.356Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:16:45.358Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:16:45.369Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:16:45.370Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:16:47.316Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:16:47.316Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:16:50.104Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:16:50.106Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:16:52.480Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:16:52.480Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:16:56.012Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:16:56.014Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:16:56.019Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:16:56.020Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:16:56.021Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:16:56.021Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:16:57.600Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:16:57.601Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:17:00.950Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:17:00.951Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:17:02.635Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:17:02.636Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:17:05.481Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:17:05.482Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:17:07.085Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:17:07.086Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:17:07.088Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:17:07.088Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:17:07.533Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:17:07.534Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:17:07.535Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:17:07.536Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:17:09.498Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:17:09.498Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:17:12.320Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:17:12.320Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:17:13.071Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:17:13.073Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:17:13.076Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:17:13.076Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:19:18.080Z [log] [HomeWizardApp] HomeWizard app ready!
2026-03-11T19:19:18.089Z [log] [HomeWizardApp] ✅ Global error handlers installed
2026-03-11T19:19:18.226Z [log] [ManagerDrivers] [Driver:battery-policy] BatteryPolicyDriver initialized
2026-03-11T19:19:18.231Z [log] [ManagerDrivers] [Driver:battery-policy] Flow cards registered
2026-03-11T19:19:18.280Z [log] [ManagerDrivers] [Driver:cloud_p1] CloudP1Driver has been initialized
2026-03-11T19:19:18.285Z [log] [ManagerDrivers] [Driver:cloud_watermeter] HomeWizard Cloud Watermeter driver initialized
2026-03-11T19:19:19.127Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Settings for P1 apiv2:  10
2026-03-11T19:19:19.170Z [log] [ManagerDrivers] [Driver:plugin_battery] [Device:0e4adb17-ee29-4052-9602-62322a12d3d0] Plugin Battery settings: {
  use_polling: true,
  polling_interval: 10,
  url: 'https://192.168.3.125'
2026-03-11T19:19:19.172Z [log] [ManagerDrivers] [Driver:plugin_battery] [Device:0e4adb17-ee29-4052-9602-62322a12d3d0] Restored URL from settings: https://192.168.3.125
2026-03-11T19:19:19.174Z [log] [ManagerDrivers] [Driver:plugin_battery] [Device:0e4adb17-ee29-4052-9602-62322a12d3d0] ⏱️ Polling enabled at init, interval 10s, startup delay 5s
2026-03-11T19:19:19.175Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🌐 Discovery: initial IP set to 192.168.3.124
2026-03-11T19:19:19.181Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🌐 Discovery: IP unchanged (192.168.3.124) — ignoring
2026-03-11T19:19:19.183Z [log] [ManagerDrivers] [Driver:plugin_battery] [Device:0e4adb17-ee29-4052-9602-62322a12d3d0] 🌐 Discovery: initial IP 192.168.3.125
2026-03-11T19:19:20.090Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔌 WebSocket opened — authorizing...
2026-03-11T19:19:22.735Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔐 Sending WebSocket authorization
2026-03-11T19:19:22.756Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ WebSocket authorized
2026-03-11T19:19:24.407Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:19:24.408Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:19:24.411Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:19:24.413Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:19:25.166Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:19:25.166Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:19:25.168Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:19:25.169Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:19:26.922Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:19:26.925Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:19:29.430Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:19:29.431Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:19:31.350Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:19:31.351Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:19:31.354Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:19:31.355Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:19:33.455Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:19:33.455Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:19:36.006Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:19:36.007Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:19:37.638Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:19:37.639Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:19:37.642Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:19:37.643Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:19:38.047Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:19:38.048Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:19:38.049Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:19:38.050Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:19:40.056Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:19:40.057Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:19:42.725Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:19:42.726Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:19:44.447Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:19:44.448Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
2026-03-11T19:19:44.451Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ✅ Battery mode command sent
2026-03-11T19:19:44.453Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] Set mode to zero_discharge_only via WebSocket
2026-03-11T19:19:45.115Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] ActionCard: Set Battery to Zero Discharge Only Mode
2026-03-11T19:19:45.116Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:dcd43b7c-f32e-417f-b75f-966f63a1f816] 🔋 WS → setBatteryMode("zero_discharge_only")
    stderr:
    CPU Warning Limit Reached
⚠ The app has crashed.
Hello Jeroen,
For the past week and a half, I have to turn off and then turn on the API switch of my P1 meter every day within the HomeWizard App, otherwise I get an error message (exclamation mark) within Homey.
The P1 meter has a fixed IP address
Please advice. Thanks!
Diagnostic report number: 0763b542-163d-4c7e-908c-34719564946d
Sounds that your homey has not stable connection your p1. If even a polling interval of 10s is not ok you face a bigger problem. I can’t help with this. I’ve added and build extra checks and timeouts to avoid this but seeing your screenshots makes me wonder the problem is your wifi.
i have a homewizard 3 phase meter to log kwh usage. is it posible to make a then chart to sent to totaal kwh of the meter?
i want to make a flow if its is the first of the month then sent tot totaal kwh of the meter to ….
if i have that data loged i don’t forget to look back and can find it easy for the bill i can sent to the tenant
You can use logic for this.
i tried but i don’t understand how yet can you explane?
there are a lot of chart for example:
total usage becomes more then…. kwh
total usage becomes les then….kwh
total usage becomes more then…. kwh for a duration of…
total usage becomes les then….kwh for a duration of…
but i can’t find a chart: if total uses changes
i also prefer to make the time and date the triger because the homey wil only start the calculation when i need it and not every time something changes just to save some memory because he is already slow
Please explain the use case and your own words.
When…
And / conditions
Action
my goal is that i get on the first date of the month the total KWH from the meter so i can manualy substract that from the reading from the previous month to make a bill for the user of the energy.
in my mind i should make the flow like:
when the time is 00:00
and the day of the month is 1
then read out the total amount of KWH
then put numberike variable to number
then send a mesage to a user
but maby my thinking i wrong i don’t know on the moment.
Here’s a job for the Power by the Hour app. It can do (most of) that for you.
You only have to add 12 variables, 1 for each month, and you have to add a flow which saves the “kWh this month” value at the end of each month to the right variable.
