[APP][Pro] Homewizard šŸ§™ā€ā™‚ļø
@Daan_Sauer These type of trigger cards are indeed not avaliable for Homey 2016-2019 models!
But, no worries, you can use this Device Capabilities app card instead:
With the water example by Jeroen, it looks like:
I don’t know if this is a good place to ask.
I have since 30th December a notification in Homey Pro early 2023 that says: Fallback baseload. It is since than every day at 06:00 am.
As I understand it comes from Homewizard.
On the 30th of December there was another notification: ā€œBaseload night invalid: sustained high consumption, strong consumption oscillation’.
On the 31st of December also: Baseload night invalid: strong consumption oscillation
But, in my energie graphic there is no high consumption of immense consumption drop.
Does anyone have a clue?
Thnx in advance,
In the app settings you can check yourself now ā€œSluipverbruikā€ or Baseload.
Check the day and you can open up the samples of that day.
I improve some tuning in the latest update (variation of fridge/freezer 100watt for a longer period)
Thnx Jeroen, I cannot find this in my app on my phone. I have the graphics shown above but I cannot open more over there. Where can I find that? I also have this:
That is Homewizard app. This is about Homey not? So check Homewizard app for Homey app settings.
Ah like that. I checked it and I had a problem. Then I restarted the Homewizard app in Homey Pro and the connection failure seems to be solved.
This is after the restart of the Homewizard app in Homey Pro
Yes, there is a new version currently being pushed so that should improve.
Ok, thank you. :+1:
No problem, it’s not perfect (yet) but it is a start. Some like it, some don’t.
Idea is when samples are there to add more analysis or triggers/flow cards based on that.
But need some datasamples first before I add more features.
I have some problems with my 1 phase Kwh meter.
It sees that it is not available, if I add it again as a non-P1 version it does work.
75963885-aa06-476b-8d0d-60540ae65b7e
Did you check the debug feature I added in the app settings?
Yes it shows the connection with no P1. Before padding the other, its says the date of yesterday. Other screen keeps loading.
Problem found, will try to fix later tonight
Thank you! Great that you can find and want to solve problems so quickly! Thanks again for the good app!
Try this test version v3.10.3
Following, having the same issue and now installed the beta version as well. Thanks for quick response!
Good to hear, its scheduled for stable hopefully today.
EDIT v3.10.4 now live
I’m running 3.10.4 but also this one gives ā€œapp unavailableā€ unfortunately. Homewizard own app is all fine.
I understand your problem. What do you mean with ā€œapp unavailableā€? Screenshot?
Sounds more a Homey/Athom thing.
Since a few days my kwh and water meters are now and then unreachable.
restarting the app helps for some minutes and then they become 1 by 1 unreachable.
I dont know if this is related to the new appversion, because i had this problem also last week.
i have made a diagnostic report 3fde8a84-97a0-4151-8434-fb993baaff70
