[APP][Pro] Homewizard 🧙‍♂️
Maybe I messed something up when reinstalling the P1 meter this evening. I tried the V2 version, didn’t work and deleted it right away.
I’ve now reinstalled the complete app and made a new diagnostics file: 152ba374-53fa-46f7-ae5e-26ead65511a4
Everything was fine until this morning. So the version before 3.8.4 worked fine.
Are you on Homey 2023?
Homey pro 2016-2019 or 2023?
2016-2019
Homey Pro Early 2023.
I checked a Homey pro 2016 12.7.1 with v3.8.8 and that works.
Any memory issues on your Homey?
No memory issues
Here also no memory issues.
Pro 2019 v12.9.0-rc.5 / v3.8.8
Phase 2 & 3 and gasmeter seem to be skipped, Jeroen. Other capabilities OK.
(Note: There’s no gas used since app install)
RAM = the usual
2f0bc441-a494-4d44-aa56-4c80ce58f509
Same here since v3.8.4 and 3.8.8!
Pushing test version v3.8.9 which has energy dongle code from 3.7.0 ( 2 weeks ago)
Try this:
Thanks. Everything works again with 3.8.9.
Tried test version?
I just did. v3.8.9 works perfect, Jeroen.
Thank you will push it live then.
Hi I have a homey early 2018 and the 3 phase kWh meter. Worked perfectly until november 3rd. I guess when the app got updated. Tried several versions of the app latest V3.8.9 but still the same issue. Only get info from phase 1 and also the total kWh usage is way to low (lower than what the meter shows on the display) I guess only usage from phase 1. What can be the issue?
No clue, drop a diagnostics report so I can see your log.
Here you go and thanks: 2E819517
Wrong one, need it from my app.
