Support Flo by Moen smart water and shutoff and water sensor.
Instructions
Add the device as you would add any device to Homey.
Enter your email address and password.
Choose your device(s) on the last screen.
Limitations
Unknown
Donations
I enjoy creating apps for Homey and try to support them as best as I can. If you enjoy using my apps a donation in return for the time I put into this is much appreciated.
Credits
A big shout out to @320_Atlantic_Avenue for providing me access to his account! Thank you!
Thank you! Thank you! Thank you!
The Flo by Moen was installed by our builder as a marketing item and not being a programmer I wasn’t sure how I was ever going to get it communicating with Homey. I think it communicated with Google Home, but functionality was so limited I never integrated it.
Thanks for building this app! Maybe I missed something, but when I try to add a shutoff device I only receive a pop-up showing ‘true’. Then it stops and wont add the device.
Could you completely remove the app, install it again and try to add your device again?
I also see that you are running on an experimental version of Homey, but I don’t think that is the problem. Also, please make sure you and Homey can access https://api.meetflo.com.
Looks like this thread has been dormant for a while. Hopefully you will see this.
I need this device to measure pressure since the pipe system in my neighborhood is 100+ yrs old and has a lot of breaks. I lose water pressure and experience reduced pressure at least once a month. Each time the water is turned on, I get a surge of muddy water into my home. This ruins clothes and dishes even if the pressure is just reduced by half. Can the pressure be monitored to give a warning that the line has broken so that I can close the valve long enough to let the mud clear then turn it back on when the pressure stabilizes?
