Integrating Fujitsu’s older heat pumps into Homey. These are the ones which support their FGLAir app.
Are you planning to support FGLair compatible aircos too?
I get a error when i want to add and login in homey. It says the login is incorrect. But it is correct.
Same here. Get incorrect login, but it is correct. (Same as my FGLair app)
Not sure how you can possibly convey this information securely, but does your login or password have any unusual characters in them? Maybe I have some kind of character escaping problem went talking to their api.
Thanks for prompt reply,
My login is an email address in this format: name@domain.no
and my password have 8 chars containing Capital letters, small letters and numbers
Mine also, but also dots.
Any idea what my login problem can be? Do you need more info on my system? Did you look at the characters?
My current thought it that there’s a different login URL for different parts of the world. I’m going to update the code to try each in turn.
I’ve published an updated version. Would be good to get feedback - thanks.
For me it works now.
Great! Thank you!
It works fine for me too. Fantastic. Thank you very much!
Will existing temperature be added?
Getting the existing temperature remains a mystery to me, but I’m looking at it. While it is easy to read the temperature, it doesnt update itself automatically, and I dont know how to trigger that. So, right now, the temperature would always show the same which is clearly wrong. I"ll work it out eventually.
Very understandable. It is actually not displayed in the FGLair app either, until you press the update button next to the temp. Before that the temperature is just shown as --.-
Since the latest update one of my airco’s constantly goes to 4 degrees
Is it possible to change the minimum to 18 degrees? That is the lowest value my units goes.
Hello Tim, Is this working with the triplesplit (ROG-18/24KBTA3) those are works with the FGLair app.?
U need to have WiFi modules in each of your airco units inside.
I have a multi split with 3 units, each unit have a WiFi module.
Hello MichelB91, Yes I have also 3 units and each unit have WiFi module. After downloading the FGLair app from the Homey Pro app, you can choose from 5 different “Airconn:” which one should you choose?
I only have had 3 in that screen.
Just add and try which one are the right ones ![]()
