FGlair
Hi!
I have an Air Condition/heat pump by Fujitsu/General. The heat pump has an integrated Wifi-module, that makes me control it through an App on my phone.
The App is called FGlair.
I cannot find any way to connect my heat pump to the Athom Homey-system. Do you have any solutions for me?
And how could I request a developer to create an App for this?
Best regards,
Martin
On a sidenote, you can buy a Sensibo which has a Homey app and use that to control your aircon.
I haven’t tried it myself yet but it should work.
Any luck on this @Martin_Ellingseter ? I have The same system. Best regards Emil
No I did not :neutral_face:
I have a Fujitsu chiller. Fujitsu did replace the FGlair App with a new version called AIRSTAGE. It depends on the WLAN module which you can to use. They are not compatible API wise.
I did a quick implementation that connects to the local WLAN module and can execute (nearly) all the commands the App can do.
If somebody stumbles upon this - GitHub - mskg/homey-fujitsu
Great!
How do I use this?
Is this working still? New Homey user…
Does this still work? I tried to install it but get error.
Hi @Markus - are you able to update your implementation for the newer API’s AIRSTAGE is using?
I send in a request via Request a Brand | Homey for Fujitsu AIRSTAGE, more ups will hopefully give as a working app?
I submitted an app to support this. Currently in testing - Fujiair | Homey
Hi, Tim_Wilkinson. What’s the status on your app? :slightly_smiling_face:
I use it every day.
Ok. I guess I misunderstood. I need something compatible with AIRSTAGE :wink: Does it require a lot of effort to make such an app for Homey?
