The earliest entry is my opple button to switch the light off. The next opple button is me switching the light on. The Timer app is an exception that I also triggered. All other behaviour is âmagicâ.
Hi @RogerSt I think I spot that you are on the main release at this point, is that correct?
If so please upgrade to the Test release, it has many improvements, and changes to my logging patterns. So debugging the old version logs are a bit harder
Can you please install the Test version and try again? see if it still has the same behavior in that version, if so please send me the log again?
Let me first check a certain app I am using which is producing inconsistent results (Timer/test) on HP23. I have a strong suspicion that it might be causing the issues, and that the device timeline events are just inconsistently logged as âtriggered by Goveeâ. I donât want to change too many variables at the same time.
Once I am sure whether or not that is the cause I will get back to you. All the best and thanks for a great response time and willingness to help!
Trying to add a Govee Air Purifier. There is an official Govee App that I am using, when I try to connect a device it says âNew devices found: select the devices you would like to addâ where the devices should be listed it just says â[object response]â I have tried Adding the device 3 separate ways. Iâve tried from the web app, which never even loads the add device page, Iâve reset the app. Logged out, logged in. Is this device just not compatible? Is this a bug with a work around?
Also I am unable to add any smartthings devices or Eufy devices. I donât know if Homey just has 3 super buggy apps or if itâs something I am doing wrong. Any help would be appreciated
Are you using the test version or the older main release?
The test version is a major release rebuild.
If you are using the test version, please restart the app try again, then send me a diagnostic report through the app settings (where you can also restart the app)
Please use the test version of the app, if your thermometer is wifi and api supported it should show up in the thermometer devices list.
Of not send me an error report
I am, but just refreshed again and it registered temp / humidity successfully!
The Govee app was showing temperature variations, but maybe it was waiting for a larger change in temperature before reporting it to the cloud?
Took about 5 hours, but working now.
Thanks for the great plugin!
Can be, the phone apps also use Bluetooth conbections, this app only uses the cloud api for appliances. To save battery those updates are less regular indeed, but 5 hours is longer than what I myself experienced so far. Maybe itâs on a spot that has weak wifi?
@Kaoh is there a way to add an extra supported device. I just bought Govee Outdoor string lights 2 (model H7038). But i see itâs currently not supported.
Just discovered it when trying to add the lights, although my API key was filled in.
Interesting Govee doesnât list it as supported while it does work. But in any case, Govee is in control of what is and what is not supported. So nothing I can do if it would not have been
