Don’t tell me what to do, and I won’t tell you where to walk! Nobody is forcing you to speak here. There is a topic, and there is my question in it. I don’t have time for your demagoguery
No.
Can you give an on topic response on why you want to revert back to a previous app update?
Then we might be able to help you…
I hope he understands what you’re asking…
guys.. i have a problem that my vibration sensor is not recognized, is there a way how to fix it?
| lumi.vibration.agl01 |
Basically, yes. To do that, the app developer needs to add this sensor to the app, because it isn’t currently supported.
Pls. check the first post in this thread to see which devices are currently supported.
hey DirkG
thanks for the comment. yes i submited a request to add this one to the app. unfortunatelly this one is just working on zigbee 3.0 vs the old one. ![]()
Any plans to support the vibration t1 sensor?
I am wondering if the T2 module also can be used with this app in a mode where it can control my blinds. If I’m looking at the app page it shows under “than” only action to set the device on or off. But I want to use it to control my blinds and also need options like; set it to a specific position.
Hi, Is there any plans to add the Presence sensor FP2? I found the FP1 and the 2 versions of the FP300 but nothing for the FP2. This would be great. Many thanks in advance. Jeff
FP2 connects via WiFi/cloud, so it likely won’t be added (this app is primarily for Zigbee devices)
I’ve been having issues with one of my two roller shade controllers (lumi.curtain.acn002) ever since a recent update. This ‘problematic’ unit seems to randomly drop offline, even though it’s located only half a meter from the Aqara relays. I’m not sure if it’s a firmware (apps or…) issue or a hardware fault. The second controller is working perfectly fine. That’s all the information I have for now.
H2 EU decoupled buttons not triggering Flows in Homey Pro Mini (Zigbee)
I have an Aqara Light Switch H2 EU connected via Zigbee directly to Homey Pro Mini. The switch has 4 buttons — 2 coupled (controlling the relay) and 2 decoupled (wireless mode).
Problem: The decoupled buttons do not send any event to Homey. When I press a decoupled button:
Nothing appears in the Flow history
Nothing changes in the device card in Homey
The Flow does not trigger
What works:
The coupled relay buttons work correctly
If I run the Flow manually via software it executes fine
The Flow logic is correct (When decoupled button pressed → Then turn off relay 1 and relay 2)
Setup:
Device: Aqara Light Switch H2 EU
Hub: Homey Pro Mini
Protocol: Zigbee (direct, no Aqara hub)
Flow structure: When → And (condition) → Then
Is there a known fix or workaround for this? Thanks in advance.
Hi there, I have 4 Aqara Curtain motor E1 modules. I can set percentages in flows and so on but is there a way to make the motor stop, with the press of a button? (any button; aqara or philips or anything) I miss the flowcard STOP
Hi
I’m struggling to connect a Light Switch H2 (2 Button) to my Homey SHS with Homey Bridge.
The Homey sees the switch when it’s in pairing mode and attempts the connection, then fails. The logs seem to suggest that the device is identified OK and the driver is selected, and then it all falls over:
Homey [err][ManagerZigbee] Error: failed to create binding (ep: 1, cl: 18) Binding table full (status: zdoTableFullStandard)
Homey [err][ManagerZigbee] Could not create node bindings ZigbeeBindingTableFullError: Binding table full (status: zdoTableFullStandard)
at file:///app/node_modules/@athombv/zstack/dist/lib/ZStackController.mjs:967:27
at process.processTicksAndRejections (node:internal/process/task_queues:104:5)
at async fn (file:///app/node_modules/@athombv/zigbee/dist/src/Controller.mjs:481:42)
at async Queue.runTask (file:///app/node_modules/@athombv/zigbee/dist/src/Queue.mjs:220:28) {
status: 'zdoTableFullStandard'
Has anyone else encountered this or have any pointers?
Thanks!
I am strongly thinking about getting a few U200 smart locks.
However I am unable to find much information about this. In the App itself the lock is not listed.
But on another page I can find it listed as supported with a small note that not all features will work (user management, nfc, 1time pins and so on).
Is anyone using U200 with Homey directly? Without any extra hub.
I am very curious to hear how it works.
And if it could be listed a supported that would give me information about what flows is supported as well. I have no idea now.
Thank!
/Marcus
i’ve got this lock. It integrates easy and smooth with Matter. No hub, no app in Homey needed.
The main stuff are basics: lock/unlock, battery level, and the event log. Thats all I really need from it. Rest is on the Aqara app (bluetooth connection).
Thank you for quick reply! Sounds great.
Hello
The Aqara vibration T1 sensor doesn’t get recognised. I see there is one model in the list of supported devices, but not T1. Homey adds it as a standard zigbee device. I wanted to measure vibration levels with it… (in a graph)
Can this be done?
