No, it isn’t listed there. Let me ask it differently then: are there any developments regarding this device to add to the Aqara app on Homey?
Is the question better this way? Apologies for the incorrect phrasing.
You can try this workaround: Pet Feeder C1 - #3 by Peter_Nass
No, I didn’t. It would require me to have the Aqara hub and run a parallel Zigbee network as well, which is unfortunately not a very feasible solution.
Hi, i got some new aqara products. Aqara Mini Switch T1. Since we already has some T1’s i expected it work, but found out the ones we had was Zigbee 1.2 and the new ones is Zigbee 3.0. Zigbee 3.0 doesn’t work with this Aqara app, will there be a support for it soon?
That would mean that my Aqara motion, door & window, en temp & humidity sensors would also not work, as they are all Zigbee 3.0 based :wink:.
The Mini Switch T1 is supported, but I suppose yours might be a different non-EU version. Based on the first post, this is the supported one:
You might want to check if you have different IDs.
I got it from Proshop.no, i live in Norway.
AFAIK that doesn’t matter, ZigBee is backwards compatible (Homey is Zigbee 3.0)
I have device id: 54EF441001187457 if that helps anything?
And what about the Product ID (so the lumi.remote.xyz identifier)?
That is likely different than the one indicated in my screenshot above/in the first post.
You could reach out to the developer to inquire whether he is planning to add support for your model.
It somehow started working through matter which it didn’t first. So everything is working now, is it possible to find the model ID in Aqara’s app? Or is it a Homey only thing?
In Homey, the product ID is displayed in the device tile’s settings and in the Homey Developer Tools (in both the devices and Zigbee sections). I don’t have personal experience with the Aqara mobile app or hub, so not sure whether the product ID is listed there somewhere.
By Matter do you mean that you connected the switch via Zigbee to an Aqara hub that is connected to Homey via Matter? Or does the switch itself support both Zigbee and Matter (I could not find that device on Aqara’s website)?
Yes, the devices is bridged by an Aqara Hub M3. Which didn’t work at first, but suddenly worked.
I’m hoping as well, that the p100 will be supported soon. Got new windows and now there is no space for a classic window sensor, even the small aqara
Hi @Liam239 , I have a Aqara Wireless Remote Switch H1, it drives me crazy with the number of alerts it gives about battery state. My understanding is that it goes into a low power mode and when it polls over zigbee to Homey it shows as low battery as it wakes which triggers the alert. Then, it hit’s normal operating power and properly reports the battery state and alerts that it ok again.
Really annoying behaviour and Homey won’t let me turn off alerts for this device and have a daily or weekly check via a flow.
Can I download a previous version of the Aqara app?
I don’t know what you’ve built there, but it’s getting annoying
Wow, what a very nice and postive approach here…
If u can do it better, be our guest…
Message me when you have a task that results in constant daily maintenance after completion
If you want stable Zigbee, why are you using Homey?
Don’t you have anyone else to talk to?! I came here with a question: is it possible to downgrade the Aqara app to an older version? If not, then no. If yes, then how… that’s it. You can keep philosophizing here, it doesn’t bother me.
Do you understand what I’m asking?
Better be a little more polite if you want something from someone else.
Works a lot better, trust me.
