You’re talking about Matter devices WITHOUT the Homey Aqara app.
So why do you mention the Homey Aqara app in your request? ![]()
Both Presense Sensors FP300 and Sensors P2 are added to Homey with Matter directly, but only FP300 shows up in the Homey Aqara app - not P2.
My FP1E is still nit usabke/malfuntionibg when trying to add it to my Homey Pro’s Zigbee network with 17 innr SO120 smart plugs, 3 x Third reality Vibration sensors and 3 Aqara Temperature sensors.
All Zigbee devices are working well. And I did the firmware update from 12.12.0 to 13.0.0 of Homey Pro 23 because I thought it would maybe improve or even solve this issue. It did not.(Athough 12.13.0 firrnware says its supposed to better stability and fixes for Zigbee.)
In the pairing process all, and really all not only in its close proximity, my Innr power plugs just do a powercycle (turn of and really fast).
see this video:
Every time you see the red led flashing (in the video ) my innr Sp120 power plug its powercycles really Quick
And my Homey Pro us max 30 cm away from these devices.
That’s not what I meant. I was referring to the response from Homey Support.
It seems you mentioned the Aqara app in your support request, which is why Athom Support says it’s not their concern. But as @robertklep already mentioned, it has nothing to do with the Aqara app when Matter devices lose their connection.
Hence my question: Why did you mention the Homey Aqara app in your support request when the issue concerns problems with Matter devices?
@TedTolboom - Would it be possible to add a 3 button Aqara wall switch with neutral wire “lumi.switch.acn040”?
(on the delivery box it was labelled as LM-E1-ZNQBKG31LM)
Thank you in advance.
Hi all, I’m contemplating buying an electrical underfloor heating system to use with the Aqara Floor Heating Thermostat W500 which is recommended in the Homey Buyer’s guide, but I’m noticing that it’s not yet listed as supported via this app. Is that correct? Any chance this could be added soon? Thank you! ![]()
Thank you @Peter_Kawa! Any tips on how I could best approach figuring this out? Maybe advanced features like the NTC temperature wire-through are not working? ![]()
No problem.
Matter mainly supports the common stuff, like set/get temperature, onoff maybe.
I bet the Aqara forum community can help you out here;
I found a post of this W500 zigbee user, maybe he/she is willing to supply a listing of all available zigbee entities:
https://forum.aqara.com/t/aqara-thermostat-w500-supports-custom-ntc-values/265356/3
All clear, thanks @Peter_Kawa! I found all information eventually on their website. I guess I’ll go with Thread/Matter for now, should be enough! Aqara Floor Heating Thermostat W500 – Aqara LLC
YW!
That was a plan!
I did not expect it to be published @ Aqara product page ![]()
Hi.
I have a Homey Pro. To this I have connected a Phillips Hue outdoor sensor that registers the outdoor temperature. I have had the temperature displayed on my iPhone via HomeKit. I have been looking for a display that can display the temperature from the Phillips sensor, via the Homey system. In this regard, I discovered the Aqara W100, and bought one. I saw that the W100 has the ability to display the temperature from a secondary sensor. It was in this field that I had hoped to display the outdoor temperature.
After trying different configurations, it seems that I need an Aqara hub and an additional Aqara sensor to set this up. It is a solution I do not want.
So the questions are if anyone,
1: has a solution to display the temperature from my Phillips sensor on the W100
Or:
2: Has another product to recommend that can display the temperature from my Phillips sensor via the Homey system.
In advance, thanks for all your help.
Hello. I have a couple of Aqara Wireless Remote Switch Double (2018) and Wireless Remote Switch Single (2018). Earlier there was a flowcard for “A scene is activated” or something, with single, dual and long press triggers in the flowcard. I don’t know exactly when the change was, but now this flow card is gone and is replaced by some “ [Button X] pressed [Y times] with no customization options in the flowcard. Does anyone know what this is about?
Edit: Also the Smart Plugs have stopped communicating like at all. Haven’t tried reconnecting them again.
I see some posts here from starting from early February and on, regarding missing flowcard and connectivity issues.
Hello, could there be an issue with configuring an Aqara Single Switch Module T1 or an Aqara Dual Relay Module T2 as being a pulse switch from within this app? It does not seem to make a difference: the relay continues to act as a toggle switch…
Is there a plan to add support for the Aqara Vibration sensor T1? The device is onlyadded as an unknown Zigbee device
I have the same issue. It has device id lumi.vibration.agl01. Also called DJT12LM.
I double checked with an Aqara Hub: I can properly configure the device to act as a pulse switch, so it must be a configuration compatibility issue with this Aqara/Xiaomi app for Homey? The other settings appear to work (like whether the attached switches are pulse or toggle)…
When can we expect to have support for Pet Feeder C1 on the Aquara app?
Hi and hello, ik want to know if the Aqara Multi-State Sensor P100 is already possible with the Aqara app in Homey Pro?
It is new and I hope the aqara app in homey will accept. Thank you.
Is it mentioned on the app page? Is it mentioned in the first post of this thread?
