[APP][PRO] Flo by Moen
Flo by Moen for Homey
App Store Page: Flo by Moen | Homey
Description
Support Flo by Moen smart water and shutoff and water sensor.
Instructions
  • Add the device as you would add any device to Homey.
  • Enter your email address and password.
  • Choose your device(s) on the last screen.
Limitations
Unknown
Donations
I enjoy creating apps for Homey and try to support them as best as I can. If you enjoy using my apps a donation in return for the time I put into this is much appreciated.
Credits
A big shout out to @320_Atlantic_Avenue for providing me access to his account! Thank you! :sunglasses:
– Reserved –
Interesting device!
But what a price… :thinking:
The first test version is available here.
Thank you! Thank you! Thank you!
The Flo by Moen was installed by our builder as a marketing item and not being a programmer I wasn’t sure how I was ever going to get it communicating with Homey. I think it communicated with Google Home, but functionality was so limited I never integrated it.
Thanks for building this app! Maybe I missed something, but when I try to add a shutoff device I only receive a pop-up showing ‘true’. Then it stops and wont add the device.
Unfortunately, I can’t reproduce your issue. Could you send a diagnostic report right after this occurs?
Sure thing! c406412f-95c1-46f8-bc55-0bbdcceec20e
It looks like it cannot retrieve an access token:
2025-07-09T11:47:29.785Z [log] [App] [Client] [c:default] [s:xxxxx] [Token] Requesting
2025-07-09T11:47:45.638Z [log] [ManagerDrivers] [Driver:watershutoff] Pair Session Disconnected
Could you completely remove the app, install it again and try to add your device again?
I also see that you are running on an experimental version of Homey, but I don’t think that is the problem. Also, please make sure you and Homey can access https://api.meetflo.com.
When attempting to access api, I received “Cannot GET /”
Bump for any help
I am seeing the same /True error could it be server problem ?
I called their support and they said my account on the server got locked. This happens all the time on Home Assistant. Doesn’t unlock automatically.
