The are mentioning an zigbee firmware issue but my issue exsist already longer even already in the 9.06 version and this problem persists over the different versions.
Wilco which homey are you using 2023?
I’m using the Homey Pro 2019
In the mean time I tried all the steps suggested by Athom and im still having the same issue. Any one else had better luck than me? Im considering that this might be an app developer issue of the “HUe without the bridge” app. Any way to contact the developer without having to create a github account?
Im seeing that the Hue motion sensors that are directly connected to homey maintains its connection without any hick up, But the sensors that were connected to homey via a router are always dropping connection after a couple of days after re-adding. Any one having the same behaviour?
Yes, on the page where you probably found the github link, there’s also a link to the
PHwotB
Philips Hue without the Brigde
app forum topic!
(It’s in the app store at the PHwotB page)
Well, it depends what brand/model router you are talking about. For instance Innr, Osram, Tuya, Aqara sometimes can be a PITA.
Unfortunately not all zigbee devices of different brands blend in 100% error free.
This sounds just like the issue with Ikea lights routers + Aqara sensors.
Replace the sensors, or the routers with preferably models from the same brand.
It’s not, all the low-level Zigbee stuff is handled by Homey itself, not by the app. An app is not responsible for (or has any control over) maintaining a connection with a Zigbee device.
Unfortunatly when you click on the link to go to the developer it automaticaly directs you to github ![]()
Look below that, in the rectangle at the bottom.
"COMMUNITY
VISIT FORUM"
Did update my homey pro 5 months ago en now the problem is again i have aqara relay en everytime disconnecting it en needed to reconnect it went this happen i have version 12.3.1 what can i do i don’t want to do this every 5 months !! Pls help
There seem to be an older version of the HUE sensors that jams up your zigbee network. Check by removing the sensor if you have it your network.
I have ikea sensor en things how i can fix that without removing it ? Rollers are ikea en 2 lights en 2 motion sensor en 4 remote switch how can i know witch one i need to remove is stil working went i check it ?
