Hi all,
I have a house filled with KNX hardware, and want to build on top of that wired backbone with a wireless solution and I came to Homey for a possibility.
What is quite high on my wishlist is comprehensive logging of everything that happens in my house: lights on/off, temperature per room in combination with when the thermostat kicked in, etc
Does anyone have any experience with Homey Insights in combination with KNX?
Regards,
Emile
AFAIK, Insights doesn’t show on/off (boolean) events, only numerical ones (temperature, humidity, brightness, etc).
If you want the most flexibility, perhaps using InfluxDB in combination with Grafana is a better choice. There’s an InfluxDB app for Homey.
Thanks for the tip, I would still like to tell me that Homey Insights works with KNX devices
Insights should work with KNX devices, but (as aforementioned) only with numerical values. So it will not show lights on/off or when the thermostat turned on/off.
