Yes, I found that out recently. Reported it to Athom.
In both cases the light is switched from the flow, so I think the history should be corrected.
Support agreed, let’s see if they change something.
But in my case, there are no actions (as far as I know) that Dim Light to xx%
All my actions for this device are turn On or Turn Off.
I happens when sensor detects no motion, the flow is started, the light is switched off and then 10 or 15 seconds (random) later the light is switched on again. I can’t find what caused this action.
Similar issues have been reported with Philips Hue and Ikea Tradfri (but that’s zigbee). I’ve not read about any solution, apart from a workaround like:
If…
Blah
Then…
Turn off Lamp Keuken
Turn off Lamp Keuken with a delay of 20s
I understand the assumption. Because of the History issue I changed the flows. Action is now Turn Light On, then 1 second later Dim to 40%.
This way the logging is better for finding the unexpected switching of the light.
Yes, I also have an extra flow.
If: Zone is inactive for 1 minute
And: Light is On
Then : Turn Light Off
I just looked in the history of a Fibaro Walli Dimmer and a Walli Switch. Switched on/off by Fibaro is listed in the history when I switched them manually.
Is it possible that a household member manually turned the switch on and then quickly turned it off again?
No, in this case that’s not possible. I saw the light go off and then after 10-15 seconds the light switched on again. There was nobody else at home. The motion sensor was also not triggered.
Could I be some Advanced Setting for this Dimmer 2 device?
These are my settings:
I have had behaviour like this a couple of times. I believe it is due to load-issues (protection). Either too low or too high to handle by the dimmer. Do you have very little load on the dimmer?
Ik believe 15W is some sort of minimum load for the Fibaro dimmer 2, otherwise you would have to use a Fibaro bypass (to add about 15W of load). But if the auto-calibration works properly, it might not be necessary.
Not fully what you ask.
Bu you can add “papertrails” to your flows. (@dijker is it still possible to have them automatically added to all your flows?)
This will at least show you which flows were triggered and executed.
For me this has helped me solve loads of issues.
(Discover flows that are triggered unexepectedly/ unintended)
Btw, although the lamp was off, the device tile of the Fibaro Walli Dimmer in the Homey app was still on!
Before that happened the first time, I changed the corresponding flows. I had always turned off the lamp with the flow card “Turn off” before. But now I replaced the flow cards “Turn off” by “Dim to 0%” flow cards.
If this was a coincidence or if it has something to do with the flow card “Dim to x %”, I can’t say for sure.
I changed the flow cards again, so that this hopefully does not happen again.
I’m trying to make this flow. And i tried in AD flow
I don’t have that card of insight in the And cards, only one that looks like it in the if card is called that one is device listening.
