Using multiple Tuya Zigbee Gateways
I have a big home with 8 Zemismart Zigbee gateways and numerous Tuya devices. I want to control everything from the Homey app and add some non-Tuya Matter devices. Apart from the Homey Pro, do I need any other Homey devices? Will the Homey pro in my living room pick up all the Tuya devices from the 8 Zigbee routers just from being on the same LAN or do I need to install some other support devices?
8(!) hubs? Why? And yea I know you mentioned having a big home. One can build just one big zigbee mesh by using enough mains powered zigbee devices (which act as hop/repeater) all over the place.
When you want to control / read out ALL of your Tuya zigbee devices connected to your Zemismart hubs:
→ install the Tuya Cloud app.
Note: it only works together with the mobile phone apps ‘Tuya Smart’ or ‘Smart Life’. Meaning, your zigbee devices should be paired with one of these apps.
Note2: The app is not actively maintained anymore, but it works fine.
Carefully follow instructions in post #1 of the app thread below, and take your time to configure the necessary stuff:
When a device is not supported when you want to add it to the Tuya Cloud app, use the workarounds ‘tap-to-run’ and/or ‘RAW commands’
Both mentioned clearly in the same post #1.
One big disadvantage, imho, is you’ll need internet to communicate with your zigbee devices. While zigbee is a local protocol.
Big advantage using Tuya hubs: any Tuya zigbee device is supported, which you can’t say when connecting them with Homey zigbee.
