The Zigbee stability issues many of us experience on Homey Pro are not a hardware limitation — they are a firmware problem with a proven solution. I’m requesting Athom to update the MultiPAN firmware on Homey Pro from the current GSDK 4.2–4.3 era to the latest GSDK 4.6, which SONOFF has already validated on the same EFR32MG21 chip.
The Current Problem
Homey Pro (2023 and 2026) uses a Silicon Labs EFR32MG21 chip running MultiPAN (RCP) firmware to handle Zigbee and Thread simultaneously. Many users, including myself, experience:
Zigbee devices dropping off the network and requiring re-pairing -
Noticeable command delivery delays -
Degraded stability as the device count grows beyond 30–40 -
Unpredictable behavior after Homey system updates that silently change the Zigbee chip firmware
With approximately 80 Zigbee devices on my Homey Pro (Early 2023), these issues significantly affect daily use and my ability to develop a Zigbee app for the platform.
This Is an Industry-Wide Recognized Problem
We are not alone in experiencing this:
Home Assistant officially deprecated MultiPAN on SkyConnect and Yellow, citing instability. They now recommend dedicated radios for each protocol.
darkxst/silabs-firmware-builder (the main open-source firmware builder) removed MultiPAN entirely: “RCP MultiPAN in multiprotocol mode is no longer available.”
Silicon Labs acknowledged memory leaks in the CPC daemon in GSDK 4.2–4.3.
The entire industry moved away from early MultiPAN — except Athom.
The Solution Already Exists
SONOFF has proven that MultiPAN can work reliably on the same EFR32MG21 chip that Homey Pro uses.
Their MultiPAN V4.6.0 firmware (GSDK 4.6) results:
100 Zigbee devices + 50 Thread devices -
Commands sent every 30 minutes to all devices -
5 weeks of continuous stress testing -
Zero crashes, zero instability
Key improvements in GSDK 4.6:
Fixed memory leaks in CPC (Co-Processor Communication) daemon
Optimized CPC task scheduling
Proper configuration tuning for MG21’s resource constraints
Source: SONOFF official blog — “Erta Revisits Multipan: Why Multi-Protocol Can Work”
What I’m Requesting
Update the Zigbee/Thread chip firmware on Homey Pro to Silicon Labs GSDK 4.5 or 4.6 via OTA, incorporating the CPC optimizations that have been validated by SONOFF and the wider community.
Athom already has the mechanism to do this — Zigbee chip firmware has been updated before during Homey system updates (e.g., Homey 5.0). This is not a hardware change. It’s a firmware update.
Why This Benefits Athom and the Community
Fewer support tickets about Zigbee instability -
Better app ecosystem — I’m developing a Zigbee app (io.zigbee.app) targeting 600+ device types, but I need a stable Zigbee stack to deliver it -
Technical leadership — don’t fall behind competitors who already fixed this -
Zero hardware cost — it’s a software update
My Setup
~80 Zigbee devices
0 Thread devices
Developing: io.zigbee.app (600+ device types planned)
To Other Users
If you experience Zigbee stability issues on your Homey Pro — please vote for this feature request and share your experience below. The more voices, the higher the priority.
Thank you, Athom team. You’ve built an amazing platform. This one update could make it significantly more reliable for thousands of users.
