The Rituals app login suddenly doesn't work anymore
I am having a same issue. I’ve set up a restart flow 5 minutes before rituals should turn on, so lets see if it works.
Same here.
Expired password notification (why?), after that the issues started. Now it keeps saying ‘Unauthorized’. Tried reinstalling the app, re-adding the device, nothing works.
So, it doesn’t work anyway. Currently completely useless and unreliable app :unamused_face:
Athom made a fix for password issue, app version 5.3.1.
But i also had contact with Rituals because i had some other issue’s with the Rituals app of Genie, including the level of scent there is in the Genie.
They told me that this “feature” of the app was removed because it didn’t worked as expected.
So, the level indicator in the Homey app doesn’t work any more.
Is this app still not working please?
App is now working fine with app version 5.3.1
The devices are still in status “unavailable” and when I tried to repair them I get “Incorrect Username or Password”. The password worked before and I haven’t changed anything. Do I need to reinstall the app and re-do all my flows?
Thanks!
Did you create a new login in the rituals app, because the native rituals app did ask for that.
That was around april this year.
If not, then logout of the rituals app en login again with new credentials.
Add the genie to homey again with thenew credentials.
It should work again.
Thank you for good info! I reinstalled and used my newer logins, it now works again!
Many thanks!
anybody facing a same issue with nonfunctional Rituals app? Stopped working like 2 days ago. It asks me to sign up again, but credentials don’t work.
Thanks for your help.
We are aware of the issue and will reach out to Rituals about this.
We’ve identified the issue and are currently working on a solution
Same here…
Hello, it works again.
