I have an issue with most of my temperature and humidity sensors mostly from Aqara. Only the outdoor one is Sonoff…
Many of them stop communicating with homey. It’s erratic they are not far from homey base. Sometimes it’s 1 hour, 16 days, 3 months…
The house is in wood. Those who stop working are note especially the ones not close to the base. The Homey base is precisely at the center of the house.
Is there a way to set the timing of updates temperature to homey?
Then, should I buy a zigbee extender ? Which would you advice ?
There is other Zigbee sensors supposed to create a route and network in between Homey and the temperature sensors by Aqara.
Three months for the bathroom is not understandable.
No. It’s event driven (= on significant temperature changes).
and
When you didn’t add any zigbee routers in the mix, you def should. Almost any mains powered zigbee device act as zigbee router.
Battery powered sensors are so called end-devices, and never act as router (to spare the battery)
Don’t use IKEA routers in the same mesh as Aqara zigbee stuff @ Homey; They DON’T mix.
(works fine @ Zigbee2MQTT though).
Aqara and Homey zigbee can be problematic, same phenomenon is reported many times: sensors just quit sending events after x days/weeks/months. Only manual re-pair fixes it for a while.
However, it’s not quite fair to blaim it all on Aqara here:
I use lots of Aqara stuff with Zigbee2MQTT, and it all runs like clockwork, even when mixed with IKEA routers…
Thanks Peter, I read the article you pointed to. My Homey is just very close to my Starlink router. I will try to separate them and see if it’s better then…
