Somfy RTS 35 Movelite via Connectivity kit koppelen aan Homey
Hi Homey’s,
I have a Homey Pro 2023, a Somfy movelite 35 RTS and a connectivity kit. Everything is working. Just not together…. The RTS motor is paired and visible in te connectivity kit. I can control it via the somfy app. I just can’t find how I can add it in Homey.
I already tried to add it via the Tahoma app, but when i click the curtains botton, it says that there are no new products….
I hope that sombody can help me out.
Best regards,
Wouter
You can ask it here https://community.homey.app/t/app-cloud-pro-somfy-tahoma-connexoon-v4-0-32-test-v4-0-35/35206
Can you send the Device log from the App Settings page.
Here is the code: 2247ec85-4f70-4f5a-91ac-107b00752c2e
I have published a new test version that supports your curtains.
That is great. Ill look on the forum how i download the update.
Thanks a lot!
@Wouter_K If you add /test behind the link from the app then you get the test version.
https://homey.app/nl-nl/app/com.somfy.tahoma/Somfy-TaHoma-&-Connexoon/test/
Thanks. It would have took me a while to find that. It works now btw. Thanks a lot!
Hello all, i am ordering Somfy movelite 35 RTS as well. just to be sure. do i need the connectivity kit in order to control the multiple curtains from Homey Pro?
No, you dont have to. I did because I also have IO screens that do need a connectivity kit. And the curtains that are upstairs cant connect to Homey directly because of the concrete floor.
