Somfy One
I have seen several apps for the integration of Somfy Tahoma or RTS but nothing for Somy One, an alarm system.
Do you know if this is possible ?
Thanks :slight_smile:
Search;
If not there;
Then go here;
Have you solved this yet?
Do you have Tahoma as well?
I have modified the Tahoma app to support the Somfy One alarm and just wondering if that would help you?
Hi, as Somfy is moving their io locks from the „Somfy Keys“ app to the „Somfy Protect“ app I was wondering if you could modify the Somfy app to support also the locks again.
So far I could add them in Tahoma and therefore have been able to use them in Homey Pro. I have moved one of the two now into the protect app and then added to Tahoma again but so far I‘m not able to add it to Homey.
Any chance you could update the app? Thanks so much
This is a very old topic and al the latest is in the Tahoma topic [APP][Cloud & Pro] Somfy Tahoma & Connexoon (v4.0.99, test v4.0.114)
At the top of that topic is a section explaining how to gather information that I require to add support for new devices.
