Shelly BLU Door and Window Sensor in Homey
The Shelly BLU Door/Window Sensor is door Homey aanbevolen, daarom heb ik er een paar gekocht. Het waren mijn eerste Shelly apparaten dus heb ik ook twee Shelly Blu Gateways gekocht.
Met die gateway heb ik de Shelly Blu door/window sensors kunnen in de shelly app kunnen koppelen en ze werken naar. behoren.
Maar hoe krijg ik ze in Homey???. M.b.v. de Shelly app voor Homey heb ik de Shelly Gateway (GWF-KZ01) in Homey gekregen, maar daar houd het op. Ik krijg de sensoren op geen enkele manier in de Homey Pro.
Wie kan/wil mij helpen?
Met vriendelijke groet,
Jacques Vork
Het is gelukt! Ze staan in Homey!
Maar hoe krijg ik ze werkend? Er is geen kaart met open/closed…. Alleen alarm aan of uit, maar open en dichtdoen reageert daar niet op. D
Hi Jacques
I am sorry I do not speak Dutch so will answer in English.
I stumbled upon your post and perhaps you have the same issue I did: Unable to get Shelly BLU door/Window sensor to report in Homey - #2 by Esben
I hope this helps.
/Esben
Hi Esben,
Thanks for your suggesties. But do you do this in the Homey app of in the Shelly app?
In Homey I don’t see a “maintainance” button.
I Succeeded to add all Shelly devies in Homey, but they don’t work propperly.
Where can I find the video you mentioned?
Jacques Vork
Hi Jacques
I just recorded this video to show what I mean: Dropbox
Basically you have to enable BLE proxy on the Bluetooth gateways you are using. You do this in Homey.
I am using a Shelly 1pm Mini gen. 3 as a Bluetooth gateway for my BLU door/window sensors.
/Esben
Daar Essen,
Hou are great, thanks!!
You solved me problem after two frustating weeks. Thanks a lot!
Jacques
I am glad it worked :smiley:
Does anyone have the problem that the ble proxy constantly turns off.
Or maybe doesn’t turn off, but stops working for some reason.
My door sensor works for a few minutes, but after that it stops responding.
I need to turn off proxy and turn on proxy again and then it works for a few minutes.
