Roller shutter status indicator in a flow
I want to use the window coverings tilt set (status indicator) of a fibaro roller shutter in a flow. This indicator shows the angle % of the slats. Using this in a ‘when’ flow does not seem possible. Anyone has a solution? Just to explain, my house has 6 venetian blinds with slats. I would like to use the slats position to trigger the light. The FP2 wifi presence sensors were not a success. Cannot get them to integrate in Homey. The Sonoff presence sensors I bought only has only 2 (unreliable) brightness settings, bright or dim.
It only seems avaliable for the Roller shutter 3
To pass the % value to the flow, add a “And” numeric logic card, pick the tag from the trigger card (always on top of the tag listing) and enter the tilt value, like, 15 (or 0.15 because flows often use 0 - 1 instead of 0 - 100% range).
That’s a pity. It should work with the Homekit Controller app. The app dev Martin is very helpful in general.
The FP2 can be a pita sometimes. But the vast majority of them integrate nicely.
