Hi, I want to use a virtual switch with a Fibaro Roller Shutter 2. So when the rollo is up, it should be off and if it is down, then on. But it seems that the flow is not working, because the status up/down of the shutter in the IF card, does not change anything, regardless the state. Can someone check or confirm this?
I made some checks and noticed, that the “State” (Value: uP/idle/ down) from the shutter is only chnaging, when I use the “App” to control it. When I use the switch in the wall, the state of the shutter doese NOT change. Threfore it must be a bug I think, because the dim Level is always shown correct and is changing also when I use the switch in the wall.
Sorry, the support page is in Dutch!!!
Can someone enter this or send this to Athom?
BTW: How can I use the Tags in Flows with the new App? I would use the Dim State instead, but I’m not able to insert the Dim State in a Flow Card as a Starting point. Any ideas here?
Sorry, its automatically dutch for me ofcourse you could take a few moments of your own time to find out the englisch form. Or is that something strange to expect from me???
Buy ey "iam not a lazy person " so here you go …….
