The ring app doesn’t work on my homey bridge.
I’ve installen the app with mfc authentication.
My flows dont work when my ringdoorbel sees motion or someone rings the doorbell. I’ve added my flow. Can anyonw help me?
I’ve also tried a flow when a Light activites that the chimney wil ring. When i run that flow i get an error 404
A 404 error means:
In computer network communications, the HTTP 404, 404 not found, 404, 404 error, page not found, or file not found error message is a hypertext transfer protocol (HTTP) standard response code, to indicate that the browser was able to communicate with a given server, but the server could not find what was requested. The error may also be used when a server does not wish to disclose whether it has the requested information.
The website hosting server will typically generate a "404 Not Found" w...
Nothing we or you can do, only Athom or Ring can fix this.
When you didn’t already, please report to Support, while Athom maintains the Ring app for Homey Cloud:
Thanks Peter!
Verzonden vanaf Outlook voor Android
