A very basic flow when my doorbell ring, send a message or just log “doorbell ring” does not work.
No problem to interact with device , and push notification from Iphone ring app works perfectly.
Hi Sylvain,
Can you at least mention which Ring app and which Homey model you use? Thanks.
Thanks. Did you also try another kind of “Then” card?
Because timeline cards can get rate-limited in certain conditions.
Yes , in fact i would like implement TTS with my Sonos or just a push message. Push Message does not work too.
You should report the non-working trigger to homey.app/support (because Athom is the Ring app developer).
In the meantime, I can recommend to install the Ring community app:
Hello, the same happened to me I think after Homey mini firmware update. I have several hours try to do standard flows but nothing. It worked to me before the update.
Now, It’s working again. I deleted old devices in Ring account and I installed Ring Community App V.2.14.11. I started from scratch again. Now is up and running.
